Using PICED software, you can now enable the backlight for the KT01 to be lit during an Entry Alert.
To do so, whenever there is an Entry Alert alarm, create a response to send a C-Bus command to the KT01 UCM, e.g. CBUS On 2 1, which switches on C-Bus group address 1.
After that, in PICED, create a button. This button should be assigned a special function (in this case, backlight on).
Next, under the Remote Control tab, set it to "Activate Component for Any C-Bus Level". Then, go to the C-Bus tab, assign the network to local, application to lighting, and group address to the group address assigned above (in this case, 1).
The button may also be "hidden" by removing the borders, text and images.
Attachment: backlight on.JPG (Downloaded 59 times)
