How to display temperature on KT01?
 Rating:  Rating
 Posted: Sunday Mar 6th, 2011 04:56 am
siamak
I tried to set a counter to the sensor register #8 witch is for the SCS with ID 1. Then I added a temperature box on the screen and set the counter number 5. I'm a little confused what application number should it be. I couldn't find in kt manual too.
regards
 Posted: Monday Mar 7th, 2011 01:17 am
Siamak
I dont know what you mean by application number
To display temperature in degrees C on the KT03, create a Value Element
This is a button that displays a number 0 to 255
In Status Properties, set Status Type = Sensor Register, and set Sensor Number to the sensor corresponding to the SCS that you have.
SCS ids 1 to 15 correspond to Sensors 8 to 23
Hence SCS 1 corresponds to Sensor Register 8
The number in the sensor registers is in degrees Fahrenheit because this is what is provided by the SCS temp sensor
To convert it to Celcius and display as such, go to Events > Sensor Responses, and assign a Response to convert F to C
Get Last Sensor
Convert F to C
Save Last Sensor
Attachment: Tempsense.jpg (Downloaded 50 times)
 Posted: Monday Mar 7th, 2011 01:20 am
A cclx file with KT03 displaying temperature in degrees C is attached
Attachment: dollhouse.zip (Downloaded 14 times)
 Posted: Monday Mar 7th, 2011 08:55 pm
siamak
Thank you very much.
 Current time is 05:59 am
