If I understand the specs I've read the recommendation is to site the UCM/Smartfit in a Unibox next to the Smartfit control box; in my case next to the hot water cylinder.
My Ultra II is about 6m away as the crows or should I say cables fly!
So I'd need to make up a bespoke cable to conncet the RS385 4 pin header on the UCM to the 4 pin header on Comfort.
Two questions then;
(a) what spec cable; is screened ie FTP Cat5e OK?
(b) what is the model/name of the 4 pin connectors I'd need to buy to terminate each end of the cable? ie what connector am I searching for on the internet as I need to buy in the UK?
Julian Last edited on Tuesday Jun 26th, 2007 11:45 pm by
