Comfort Automation/ Security System Forums > Products > UCM > UPLOAD and DOWNLOAD buttons on UCM
 Posted: Monday Jun 17th, 2013 09:58 am
This applies to UCM/USB, UCM/ETH02 and UCM/232 with firmware 6.080 and above
The U2 EEPROM on the UCM can be used to save the Comfort configuration
To read the configuration from Comfort and save in the U2 EEPROM on the UCM, press and HOLD the UPLOAD button on the UCM for 2 seconds, until the BUSY1 (RED) LED starts blinking. This takes about 2 minutes. When the operation is complete, the BUSY1 LED wlll stop blinking and turn off, while the Green RDY led will be on.
To write the saved configuration in the UCM U2 EEPROM to Comfort, press and hold the DOWNLOAD button for at least 2 seconds until the BUSY2 LED starts blinking. This takes about 1 minute. When the operation is complete, the BUSY2 LED wlll stop blinking and turn off, while the Green RDY led will be on. This works only if the File system in the U2 EEPROM matches that in Comfort, ie the 2 configurations are compatible. This prevents invalid configuration from being written to Comfort
This method can be used to save a working Comfort configuration including all programming and user codes. If user codes have been forgotten, then pressing the DOWNLOAD button will restore the saved configuration including user codes to Comfort. Hence once the comfort configuration has been fully tested, use the UPLOAD button to save the configuration to the UCM
Note that this procedure does not require Comfigurator
Check out the Video showing this procedure at https://www.youtube.com/watch?v=I_-P5Bd9EiI
Instructions on upgrading UCM firmware can be found at http://www.comfortforums.com/forum92/3400.html
 Posted: Monday Jul 13th, 2020 06:52 am
Save Comfort to UCM EEPROM and Read from UCM EEPROM to Comfort
The UCMs (UCM/USB, UCM/ETH03) have an EEPROM that is used for backing up of the configuration in the Comfort controller.
This is useful when the configuration has been corrupted. It also backs up the user codes so when the user has forgotten the user and or engineer codes this can be used to restore the codes.
Comfigurator 3.13.1 and above  has a function to write Comfort > UCM EEPROM and Read UCM EEPROM to Comfort in the Transfer Menu
This requires UCM Firmware 7.131 minimum.
see
http://www.comfortforums.com/forum20/5159.html
 Current time is 07:44 pm
