I have a UCM05/Ethernet that will not connect. everything is as it should be. J2 is RS485. id1, sw8-f connected only. Flow control disabled on DS Manager. D9 and d10 flashing, RDY ON, 102 ON and 103 flashing twice every few seconds (not Connected). DS Manager works fine so Ethernet cable okay. UCM05 works fine when changed to serial.
Comfigurator3 times out and says "failed to connect to UCM"
All Current firmware:
UltraII- 5.164
UCM-5.178
DSmanager-CYTEM334
Comfigurator-3.0.1
What am I missing?
Could it be that you select the wrong port number for UCM/Ethernet in Comfigurator?
The default port number for UCM/Ethernet is 1001, NOT 10001 (which is for CWM02).
