UCM Versions
 Posted: Tuesday Feb 10th, 2009 08:20 am
Being trying to check the versions of the 3 UCM's I have in my system.
Assumed I could use u?11, u?12, u?13 respectively to do this via the UCM I/O monitor but nothing comes back.
What am I doing wrong.  Obvously the UCM connected to teh PC reports back via the U? command but surely I should be able to get the same info back from the u? command as well.
J
 Posted: Tuesday Feb 10th, 2009 08:23 am
This needs a firmware upgrade to Comfort as well 5.163 which shall be released shortly
 Posted: Friday Feb 13th, 2009 09:02 am
Are you able to share what the ETA is on this firmware?
J
 Posted: Friday Feb 13th, 2009 11:58 am
Comfort firmware 5.164 has been released to production although it will take some time to go to new customers
We will be uploading the firmware for upgrade probably next week
 Posted: Saturday Feb 14th, 2009 04:12 pm
OK I've re-run this "u" test with Beta 5.166 today and get the following:
> SR01
< OK
> u?11
< u?110A05B2
> SR01
< OK
> u?12
< u?12000000
> SR01
< OK
> u?13
< u?130A05B2
So you can see my two UCM05's; ID's 1 and 3 report their versions correctly.  My Smartfit UCM (ID 2) reports all zero's; is this because it needs an update to the UCM firmware too to make it report?
How long should I hold my breath for a new version of Smartfit firmware IC (that also fixes my "69" issue);  ie what depth of blue would you like me :D.  I'm thinking the answer is probably "don't hold your breath"!!
When I look at the smartfit UCM isn't it purely the old style UCM base board loaded with a Smartfit firmware and then holding the Smartfit specific microcontroller daughterboard?  If you had a flash version of the UCM firmware wouldn't it be feasible to plug this daughterboard into a newer UCM05 (via the 10 way connector) and use a flash smartfit firmware to make it easier to keep up to date? I'm sure it's not quite that simple but hopefully you get where I'm coming from?
 Posted: Sunday Feb 15th, 2009 02:36 am
Thats right, the UCMs need a new firmware update to be able to report their firmware version to the u? command. This requires the new flashable UCM PCB instead of the old style UCM with the U1 IC in a  socket that you have. We currently do not have Smartfit firmware of the flashable type as there has been no demand for it in several years. Even so that would not solve the problem of the 69 value when heating is off
I have looked through old correspondence - this was actually reported to Honeywell in 2002 as an issue with the Smartfit protocol
 Posted: Sunday Feb 15th, 2009 03:02 am
The answer given by Honeywell in the Smartfit forum
http://www.comfortforums.com/view_topic.php?id=708&forum_id=42
The setpoint transmitted by the room unit when Off has been selected has a specific value to indicate Off. In hexadecimal this value will be in the range 7E00 to 7EFF, and should be decoded as an Off value, Cytech should have this information.
also indicates that there is no meaningful value of Room Temperature setpoint when the heating is off. Comfort has to report a value, so perhaps it was the last valid value
 Current time is 08:05 am
