adlim
Posts: | 210 |
Comfort Responses can be triggered by Dynalite switches, e.g. pressing a Dynalite switch triggers a Comfort response to send an IR code via one of Comfort's outputs. To do so, the Dynalite DNG232 and Comfort's UCM01 or UCX01 have to be used. In such as conifguration, the Dynalite DNG232 is used to monitor specific commands sent on the DyNet. Whenever one of the commands specified is sent by the Dynalite switch, the DNG232 serves to login via the UCM/UCX as one of the users on Comfort using the LI command (for further information refer to the Comfort Serial Set), as well as the desired command to trigger Comfort's responses.
