Need Help
 Posted: Monday Nov 26th, 2007 09:39 pm
slayer91
Hello,
This morning upon leaving my house, I notice that the keypads did not have any display present and  none of the PIRs flashed as I moved across them.
 A check of the main panel show that the back up 7ah lead acid battery had failed (no warning from Comfort). It appear to be dragging down the boards power supply. When I disconnected the battery, the output from the traffo to the board was restored to 14v approx. But I still had no 12v supply to the zones or the keypads. I reset the board and the leds do their sequence until the green flashes on/off slowly. None of the power components and heat sinks are hot.
When I used the local phone, Comfort tells that 'Communications Failure 66, and then goes on to list the main menu.
Do I need to replace my backup battery before the system will output the 12v to power the keypads and zones.
Do I have a short on one of the 12v outputs to the PIRS??
Any other things I can check..I really need to get this system back and running.
System Details
Installed and commisioned early 2006.
Comfort version 1 (4.222)
1x LEM
2 KP04
1X DP02
Regs
Liam K
 Posted: Tuesday Nov 27th, 2007 03:41 am
There may have been a short on the 12V supply from one of the external devices like PIRs or wiring.
Disconnect the terminal block from the 12V connectors and leave for 10 minutes
The 12V supply is protected by a resettable fuse  which activates when there is excessive current. When the load is removed, the fuse recovers.
If the 12V is restored, then look for shorts on the 12V wires
 Posted: Tuesday Nov 27th, 2007 09:52 pm
slayer91
Thanks for the reply, suspected as much. Disconnect each of the keypads and door station in turn. Again had suspicions on doorstation as it is outside the house and we had a bitterly cold few days. Once the doorstation was disconnected, the 12v supply was restored. Like the resettable fuses, they are a good idea.
Do ye have any irish agents for Comfort??? Need to replace the door station asap.
Liam K
 Posted: Wednesday Nov 28th, 2007 12:40 am
Yes, ID Electronic Solutions is in Ireland, their contact details can be found at
http://www.cytech.biz/cytcms/dealers.php#IE
There will be a new version of the Door Station DP03X which works with the DM02 inside the house so that only the speaker and microphone circuits are in the Door station outside the house. This reduces the exposure of the Door station to the environment and may prevent such a situation
 Posted: Saturday Dec 8th, 2007 10:16 pm
slayer91
Is there somewhere I can send the PCB to get it repair????
LiamK
 Posted: Sunday Dec 9th, 2007 02:40 am
Please send it to the same dealer or distributor that you bought the system from
If yiou cannot locate them for aby reason, please send an email to support@cytech.biz with your fulll name, address and contact number
regards
 Posted: Friday Dec 14th, 2007 07:29 am
slayer91
Have sent you a private message
 Current time is 11:18 pm
