Posted: Monday Sep 3rd, 2007 07:15 am |
palmlodge
Posts: | 507 |
Two issues
1. WizComfort hasnt been working for ages - until I noticed the "bind to IP address" - my IP will change because of dhcp. This now works. Comfigurator doesnt need this - why does wizcomfort ?
2. With my latest config, wizcomfort is now showing the CBUS tab - how can I enable this ?
Posted: Monday Sep 3rd, 2007 08:38 am |
adlim
Posts: | 210 |
1. If you are using DHCP, then do not fill in that field.
2. Does your CCL file have a UCM defined as a CBUS type? If you do and it does not work, try selecting the CCL file again.
Posted: Monday Sep 3rd, 2007 08:51 am |
palmlodge
Posts: | 507 |
Adrian
Yes, my UCM is defined as CBUS in the CCL and i've got no issues with the Comfort <> CBUS talking
I've also noticed WizComfort doesnt list any of the time programs either
Posted: Tuesday Sep 4th, 2007 12:26 am |
adlim
Posts: | 210 |
Have you tried reselecting the ccl file under setup?
If it still doesn't work kindly send the ccl file to me to investigate.
Posted: Tuesday Sep 4th, 2007 05:27 am |
palmlodge
Posts: | 507 |
Yes, I have multiple ccl's, as each new change i do creates a new ccl.
sent via email
Posted: Tuesday Sep 4th, 2007 06:04 am |
adlim
Posts: | 210 |
Don't seem to be facing the same problem.
Could you send me the 2 ini files in the WizComfort directory?
Posted: Tuesday Sep 4th, 2007 06:06 am |
adlim
Posts: | 210 |
Here's the screenshot.
Attachment: wiz.jpg (Downloaded 40 times)
Posted: Tuesday Sep 4th, 2007 07:44 am |
palmlodge
Posts: | 507 |
done - here's my screenshot
I see on YOUR screenshot the outputs tab is greyed out - and do the time programs list on yours ? they dont on mine.
Attachment: 1.jpg (Downloaded 40 times) Last edited on Tuesday Sep 4th, 2007 07:45 am by palmlodge
Posted: Tuesday Sep 4th, 2007 08:17 am |
adlim
Posts: | 210 |
The outputs tab is greyed out as I did not enable the settings. No problems after doing so.
I noticed that you did not specify the ifr directory and iomap locations which I believe are the cause of your problem.
Posted: Tuesday Sep 4th, 2007 09:17 am |
palmlodge
Posts: | 507 |
Odd, I've never set those values before. I've set them now, restarted wizcomfort, same problem.
And if i remove the bind to local ip address, the damn thing keeps coming back (192.168.0.1)
Posted: Wednesday Sep 5th, 2007 12:04 am |
adlim
Posts: | 210 |
I made a mistake: Should enter the Bind to IP to 0.0.0.0 instead of erasing.
What values did you set them (the iomap and ifr directory) to?
Posted: Wednesday Sep 5th, 2007 06:39 am |
palmlodge
Posts: | 507 |
C:\Program Files\Cytech\Comfigurator\ifr
and
C:\Program Files\Cytech\Comfigurator\iomap.cym
Posted: Thursday Sep 6th, 2007 06:53 am |
adlim
Posts: | 210 |
We have identified the problem which is caused by the CCL file being located in another PC on the same network and not on the PC running WizComfort itself. We would advise all users to locate the CCL file on the PC running WizComfort while we work on a fix.
Posted: Thursday Sep 6th, 2007 04:56 pm |
palmlodge
Posts: | 507 |
Prob explains why WizComfort will crash when trying to load every 1 out of 4 loads (or so)
