Have you left the Tamper input disconnected? This could be causing am alarm, and thiuius the red led to flash.
Disconnect everythng except a keypad and load a default file into Comfort, and see if there are still problems.
Check that the ids of each module are set correctly and not conflicting before you connect them
Also it would be good to give the firmware version of the Comfort system
regards
