Comfort 2 not allowing sign in.
 Posted: Thursday Feb 22nd, 2007 02:05 pm
palmlodge
Well, this was working...
I no longer seemed to be able to sign in remotely - neither on the house phone, nor from dialling in remotely.
Problem we had before when this did not work was the record level was low, so now I've put it up to about 85%
Anything else that can turn this off ? Pressing the * key to sign in furiously does nothing.
 Posted: Friday Feb 23rd, 2007 12:07 am
adlim
How about the keypads? Do the keypads still allow you to sign in?
 Posted: Friday Feb 23rd, 2007 07:08 am
palmlodge
I can still login/ etc via the keypad ok.
 Posted: Friday Feb 23rd, 2007 10:46 am
The Record Level was originally about 20%, you have increased it to 85%. As the scale is logarithmic the level has been increased perhaps by a factor of many tens, and the signal may be saturating, ie exceeding the maximum signal level. The DTMF tones would be clipped off.
Reduce the Record level back to the original level and increase it by a smaller increment to get an acceptable record level.
Also see the Tuning Parameters Guide at http://www.cytech.biz/temp/techinfo/Tuning%20Guide.pdf
which shows the effects of Tuning parameters on volume and DTMF
 Current time is 06:21 pm
