Reset Engineer Code?
 Posted: Friday Dec 9th, 2016 02:39 pm
jonodublin
I have a 4.169 console.  The system has been connected, but, really unused for over 10 years (maybe more).
I don't have contact details for the original installer. I am waiting for a USB/RS232 cable to see if I can pull the details into Comfigurator.
I have some questions..
1) Can I see the engineer code in Comfigurator? If not, how can I reset?2) What is the specific module I need to connect it to my ethernet. I know there are newer versions..3) Are there any installers in Ireland?
David
 Posted: Saturday Dec 10th, 2016 06:29 am
You cannot see the user or engineer codes in Comfigurator - they are hidden
If you know 1 code, user or Engineer, then you can change the user or engineer code and "write user codes to Comfort". You will need to know one  user or engineer code in order rto Read from Comfigurator anyway
The default engineer code is 6789. If it has not been changed then try that. Press F0 on the keypad before entering the engineer code
Please contact  KNX Tech in Ireland for assistance
    32 Wilson Rd.
    Mount Merrion
    Churchtown
    Co. Dublin
    Ireland
    Contact: Niall Walsh
    Tel: 00353879896428
    Email: niall@knx-tech.eu
    Website: http://www.knx-tech.eu
 Posted: Thursday Apr 19th, 2018 11:04 am
shahvij
Hi - I am on comfiguration version V.3.12.4.0
Controller - 7.117
UCM01 7.098
I have forgotten the engineering code. and even to write user codes to comfort - I need to enter the engineering code after F0 - how can I solve this ?
 Posted: Thursday Apr 19th, 2018 12:36 pm
If you know one of the user codes you can use Comfigurator to write the user codes
If you have lost both User and Engineer codes then you will not be able to reset the code by Comfigurator or keypad
Please contact Laser to find an installer who can reset it for you.
    16 Garthland Drive
    EN5 3BB
    Barnet
    Hertfordshire
    Contact: Marie Li
    Tel: +44 20 8441 9788
    Email: info@laser.com
    Website: http://www.laser.com
 Current time is 05:16 pm
