Posted: Thursday Sep 15th, 2016 04:46 pm |
emabonacchi
Posts: | 83 |
With any reason, today my Cytech stop working.
Trying to solve the problem, i have connected pc and this is the error message:
Unhandled exception:
System.NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.
in Comfort.Form1.ScanForUcms(Configuration configuration)
in Comfort.Form1.ScanForAllModules(Configuration configuration)
in Comfort.Form1.uploadComfortPCToolStripMenuItem_Click(Object sender, EventArgs e)
in System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
in System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
in System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
in System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
in System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
in System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
in System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
in System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
in System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.ScrollableControl.WndProc(Message& m)
in System.Windows.Forms.ToolStrip.WndProc(Message& m)
in System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Some suggestion?
Posted: Thursday Sep 15th, 2016 04:59 pm |
emabonacchi
Posts: | 83 |
Another message:
"File system 34 is not compatible with. Select file system 34."
Posted: Thursday Sep 15th, 2016 05:18 pm |
Posts: | 5499 |
Can you open Monitor I/O and log in?
copy the IO monitor and send it
Posted: Thursday Sep 15th, 2016 05:20 pm |
emabonacchi
Posts: | 83 |
No, i can not connect with ucm more.....
slychiu wrote: Can you open Monitor I/O and log in?
Posted: Thursday Sep 15th, 2016 05:25 pm |
emabonacchi
Posts: | 83 |
LI****
LI****
UL000003
UL000003
UL000003
V?
v?
Posted: Thursday Sep 15th, 2016 05:28 pm |
emabonacchi
Posts: | 83 |
Error writing configuration. Response = NA
Posted: Thursday Sep 15th, 2016 05:35 pm |
Posts: | 5499 |
It looks like there is a fault
what are the state of the leds on Comfort?
You may have to use UCM with Firmware prgramming cable and see if you can upgrade the firmware (to latest version)?
Posted: Thursday Sep 15th, 2016 05:45 pm |
emabonacchi
Posts: | 83 |
d2 green, fixed on
d1 red, fixed off
Posted: Thursday Sep 15th, 2016 06:38 pm |
emabonacchi
Posts: | 83 |
d9 red blinking fast
d10 green fixed on
Posted: Thursday Sep 15th, 2016 07:01 pm |
emabonacchi
Posts: | 83 |
I can read event-log.
Does it mean ucm is working?
Posted: Thursday Sep 15th, 2016 07:06 pm |
emabonacchi
Posts: | 83 |
Reading event log, only read 2% and date and time are uncorrect (for example "88/01 05:37").
Posted: Friday Sep 16th, 2016 10:11 am |
Posts: | 5499 |
If you can read the event log, it means UCM and Comfort both are working
on UCM D9 Red is blinking and D10 Green is binking fast so it appears to be permanently on
Right Click on Modules , Scan for Modules and check that all the modules eg Keypds, UCms are found
Do a Write to Comfort with your cclx file
Posted: Monday Aug 20th, 2018 07:34 am |
sonamg
Guest
Posts: | |
Yes it looks like there is some fault
do you have to use UCM with Firmware programming cable and look if you can upgrade the firmware?
