A quick diagnosis of the circuit, use a multimeter to do a buzz test with the contact open/closed it sounds to me as if the wiring maybe damaged for it to be an open circuit, any electrician will be able to check the cable with that simple test, also did they test the new sensor?
as for the door station that sounds like that the system may need to be reprogramed with all the new parameter.
Just an after thought try using an older version of comfigurator, esp when you first had the door station first installed (it maybe buggy, and that may explain why your installer had issues getting it right, should have just changed whole unit rather messing around with swopping parts)
