Posted: Saturday Oct 25th, 2014 11:47 pm |
Howser
I had two cases where when opening the garage door, the control panel did a soft reset. The first occurrence the alarm was in day mode (which was a concern as the panel takes a while announcing zones before re-arming).
I looked at the logs and found the following
10/25 12:10 DSP/Voice Fail 1
10/25 12:10 DSP/Voice Restore 97
10/25 12:10 Reset 97 |
The same issue was in my older logs 12/03 11:31 DSP/Voice Fail 32
12/03 11:31 DSP/Voice Restore 97
12/03 11:31 Reset 97 |
I am using Comfigurator 3.9.2 with Ultra II version 7.061, two slaves (version 6.068)
Posted: Sunday Oct 26th, 2014 06:17 am |
Posts: | 5493 |
DSP Voice Reset occurs when the voltage to the DSP falls to a low level and the voice is disabled to prevent corruption and lost voice. Comfort automatically resets itself to recover the voice, hence "Voice Reset"
The garage door operation may have caused the voltage on the system to drop momentarily. Perhaps due to a noise spike or could it be a problem with the backup battery?
Posted: Sunday Oct 26th, 2014 10:05 am |
Posts: | 557 |
Running the garage door motor from the Comfort 12V supply?
Posted: Sunday Oct 26th, 2014 11:30 pm |
Howser
Ingo wrote: Running the garage door motor from the Comfort 12V supply?
No, the garage door has it's own 24 volt battery.
Posted: Monday Oct 27th, 2014 07:50 am |
Howser
slychiu wrote: DSP Voice Reset occurs when the voltage to the DSP falls to a low level and the voice is disabled to prevent corruption and lost voice. Comfort automatically resets itself to recover the voice, hence "Voice Reset"
The main panel is some distance away from the Garage, and they are not even connected to the same power source phase. I had a look at other logs I saved prior to noticing the two occurrences I stated, and there is an additional DSP Voice reset that did not occur when the garage door was open.
Posted: Monday Oct 27th, 2014 08:15 am |
Posts: | 5493 |
Perhaps some instability of the AC power supply or surge getting into the system from outside
The DSP reset /restore is a protective mesaure which may prevent the loss of voice
