engineering code
 Posted: Monday Sep 1st, 2014 08:06 am
hasan hadi
how can change engineering code for anther code
also anther equation if engineering code is disable this mean cannot access from any where by using IP static
Attachment: enginer code.png (Downloaded 35 times)
 Posted: Monday Sep 1st, 2014 09:42 am
change the engineer code from Security > Sign In codes
It is not necessary to set "Require Engineer Code to write to Comfort". This means you cannot use a user code to write to Comfort, but you must use Engineer code
It has nothing to do with Static IP address
 Current time is 10:25 pm
