Zone state
 Posted: Monday May 12th, 2014 06:40 pm
fpicard102
HI,
I use magnetic contact with 2 EOL resistor (2k7 if contact is closed and 2k7+4k7 if contact is opened).
I have the same configuration on all doors/windows. I have connected zone to UCM but only window or door connected to Z1 has the good state. All other zone stay inactive.
Can you help me????
PS: If I change wiring Z2 to Z1, the state of Zone 1 is good compared the window state, so I think my contacts are connected correctly
REGARDS
 Posted: Tuesday May 13th, 2014 07:13 am
Sorry but I dont understand why you have connected the zone to UCM?
Have you programmed the zones in comfigurator with the correct zone state
By default only Z1 is programmed, others are Null zone state
 Posted: Tuesday May 13th, 2014 09:07 am
fpicard102
Sorry, I do a mistake, it´s connected to main board not UCM :)
I'm in my first investigation for programming. My problem is the zone status. Contacts connected to zone 1 change the status of the zone ( inactive to active) when my window is open (24hrNC). On ipad the red cross change to a green point. But it´s the only zone that works
Regards.
PS: sorry for my english, it´s not my native language :)
 Posted: Friday May 16th, 2014 08:45 am
fpicard102
Please,
Someone can help me to understand why ONLY zone 1 give me a status?
Is it necessary to program?
 Posted: Friday May 16th, 2014 10:54 am
You need to use Comfigurator to program the zones
Only zone 1 is programmed by default
 Posted: Friday May 16th, 2014 11:59 am
fpicard102
I'm Ok but in this case I don't understand Where and What I need to program to obtain status. Can you give me some explications?
 Posted: Saturday May 17th, 2014 12:44 pm
What exactly do you mean by "obtain status"
Have you programmed the zones?
do you mean "Show status" box in the zones right pane?
If you check the box then you can see the status of the zone
 Posted: Saturday May 17th, 2014 07:54 pm
I think the user might benefit from this:
http://www.cytech.biz/download_files.php?item_id=280
 Posted: Tuesday May 20th, 2014 12:02 pm
fpicard102
Thank you for you powerpoint. I resolved my first problem but I was obliged to re-install configuration.
During scan module I have detection of Keypad, but no keypad are wiring to my system. Is it normal?
 Posted: Tuesday May 20th, 2014 12:42 pm
You may be detecting some keypads, but please wait for 1 minute and do the scan again
This may happen with comfigurator 3.87-3.88 with comfort firmware < 7.036
 Posted: Wednesday May 21st, 2014 04:07 pm
fpicard102
Dear Ident
Is it possible you send me your powerpoint "Comfort to knx" ?
 Posted: Wednesday May 21st, 2014 04:09 pm
You can download from http://www.cytech.biz/knx_interface_training.html
 Current time is 05:45 am
