battery warning controller
 Posted: Sunday Dec 8th, 2013 04:21 pm
bullsim
I am just commissioning my alarm. I am getting a battery warning controller. I charged the battery with a optimate pro charger after I had this for 5 days. Any tips on what it is and why I can not reset it?
 Posted: Monday Dec 9th, 2013 01:12 am
Do this test
Connect the battery to the system and switch on the power
When Comfort has announced, switch off the AC power
Does Comfort remain on? This tests the battery voltage and whether it can power the system. Measure the battery voltage at the terminals. It should be 12V. The battery voltage can only be measured when there is a load. Without any connection, bad batteries may have 12V measurement
Which Comfort do you have Comfort 1 or 2, and is it a new system?
If it is Comfort 1, look for the charging bulbs near the battery connector. They may be burned
Comfort 2 does not have this problem
 Posted: Monday Dec 9th, 2013 05:32 pm
bullsim
I tested it. the unit stays on when I remove the power,and reports power failure.
I cant test the voltage as I dont have a volt meter (but will get one tomorrow). I do have an optimate pro battery charger and i sent the battery to new and it carried out a full test. If the battery had a genuine issue it would show on that charger given its capability ie before it charges it tests the battery fully.
its a Comfort II ULTRA Control Panel,
 Posted: Tuesday Dec 10th, 2013 01:17 am
Can you give me the serial number of the Comfort PCB, it should be C followed by 6 numbers eg C123456 printed on a label
 Posted: Tuesday Dec 10th, 2013 11:31 pm
bullsim
yep the number is C059619
 Posted: Wednesday Dec 11th, 2013 01:33 am
Thanks, that is a new system
When you get hold of the mutlimeter, please check two things
  1. The voltage on the battery terminals when connected to Comfort but AC power is off. This gives the battery voltage when loaded
  2. The voltage on the battery terminal on the PCB when the battery is not connected and the AC power is on. This shows if there is voltage available to charge the battery. It should be 13 to 14 volts
 Posted: Wednesday Dec 11th, 2013 10:03 pm
bullsim
ok the numbers
1 power off battery on only 13.4v but it drains very fast. ie just holding the multimeter it went from 13.4 to 12.9
2. power on, battery disconnected 13.7v
in terms of modules. There is LEM, zwave and the ethernet module.
 Posted: Thursday Dec 12th, 2013 12:59 am
When you say the battery voltage goes down very fast from 13.4 to 12.9, does it continue to go down to below 12V when the AC power is off?
A good battery should go down quickly to slightly above 12V and drain slowly from that point. A low battery voltage is 11.5V.
 Posted: Thursday Dec 12th, 2013 07:59 am
bullsim
Well after 15 minutes its steadied at 12.78 and its very slowly going down.
 Posted: Thursday Dec 12th, 2013 08:17 am
That is the normal behaviour
After resetting Comfort, after how long do you get the Low battery message?
It may be detecting the low battery wrongly if the low battery alarm still occurs. If so you can get a replacement from your supplier
 Posted: Thursday Dec 12th, 2013 08:19 am
bullsim
The low battery has shown for days and I have reset the unit multiple times. I am wondering if its the main board, is that your thoughts?
 Posted: Thursday Dec 12th, 2013 08:27 am
Does the low battery alarm happen at the same time every day?
You need to sign in on the keypad in order to acknowledge it otherwise the low battery alert will remain on your keypad
when you sign in on the keypad does it say Low battery restored?
Or does it not say that it is restored when you sign in?
 Posted: Thursday Dec 12th, 2013 08:57 am
13th Post
bullsim
It says battery warning twice and then welcome. It never clears the message from the keypad.
 Posted: Thursday Dec 12th, 2013 09:38 am
14th Post
That probably means a problem with the Comfort PCB
Please request for a replacement
 Posted: Thursday Dec 12th, 2013 02:28 pm
15th Post
bullsim
You be pleased to know I have had the board swapped out and its now fixed the issue. Thanks for your help.
 Posted: Saturday May 10th, 2014 11:41 am
16th Post
I've been toying with this problem over the last couple of weeks on my test system and only got around this morning to put a test meter across the outputs under load; all looked well.
I then suspected cable issue and put meter on the connector end that plugs onto the PCB; that looked good too.
Plugged the connector back into the PCB and tested and it all worked.
Doh!  So moral of story is to suspect dry-joints too and re-plug first!. Serves me right and why I've been getting an early morning wake-up keypad bleep/alarm every morning this week.
 Current time is 12:54 pm
