ULT 7.045
 Posted: Tuesday Nov 26th, 2013 05:33 pm
After upgrading to 7.045 a learn of my UCM/HM doesn't seem to find my thermostat anymore?
Also seeing a few of these in recent builds.
Attachment: timeout.jpg (Downloaded 15 times)
 Posted: Thursday Nov 28th, 2013 01:24 am
Juwi, this is a problem with Comfigurator 3.7.7 not ULT
In older  Comfigurator, the module scan sometimes  takes a littel longer to get a reply from a module and Comfigurator reported it as not found
In Comfigurator 3.7.7 if the scan reply u? is too slow it gives the message that you see and asks you to try again
If you repeat the scan it should see the UCM/HM
If you have the same problem can you send the Monitor IO
 Current time is 11:36 am
