Flags
 Posted: Wednesday Mar 28th, 2012 02:56 pm
lwillerton
I want to open my electric gate every other monday. I have written a response that opens the gate and keeps it open as expected. However, it does this everymonday and not every other monday. I have a timed program the runs at 8:15 every Monday that toggles a flag and I expected this would work.
I have added the flag to the control menu as a feedback this remains at 0 at all times. I have setup 3 test responses 1, set, 1 clear and 1 toggle and run each on in turn and checked the feedback state which remains at 0.
Any thoughts
Lee
Attachment: Flag.JPG (Downloaded 30 times)
 Posted: Thursday Mar 29th, 2012 04:04 am
We have tested your file, there is nothing wrong
The flag toggles as expected
If you execite the Wheelbin Response, it toggles te flag and if state is 0 the output turns on
type R!AB execute Response 171 in Monitor I/O
You will see F?1401 or F?1400 as flag status
and OP0201 output 2 on
Control Menu status - You have to update the status by checking show status
Check flag status using command F?14
 Posted: Thursday Mar 29th, 2012 07:29 am
lwillerton
The F?14 really helps, do you have a list of other commands?
Also do you agree that the wheel bin response should only activate every other week? there is a time program runs evrry monday that toggles the flag and checks rhe flag status before running.
Cheers
Lee
 Posted: Thursday Mar 29th, 2012 08:16 am
see attached protocol
your program should be correct
Attachment: comfortprotocol.pdf (Downloaded 5 times)
 Posted: Thursday Mar 29th, 2012 11:14 pm
lwillerton
Thanks.... and yes the flag toggles.
I have started to do a bit more work with flags but getting a little lost I have a couple of response which simple says set and clears a flag (10 autoarm). As per the auto arming idea. Anyway if I do F?10 the run  the set responses from configurator and then type F?10 again I get:
> F?10
< FL1000
> DA840A01FF
< FL0A01
< RA00
> LI
< LU00
> LI****
< LU02
> F?10
< FL1000
What am I doing wrong?
 Posted: Friday Mar 30th, 2012 02:47 am
F?10 is referring to Flag 16, not 10
The numbers are in Hexadecimal notation when you enter these commands
try F?0A
 Current time is 06:34 am
