Posted: Tuesday Mar 20th, 2012 01:06 pm |
bodsmate
Posts: | 21 |
Would someone please confirm an actual AC voltage reading of a GEN2 transformer when connected to comfort?
I understand this should be around 15.5VAC - but would like someone to confirm what they are actually getting on the comfort AC in terminals
Many thanks
Posted: Wednesday Mar 21st, 2012 04:59 am |
You should measure 14 to 16.5V RMS
Posted: Wednesday Mar 21st, 2012 01:22 pm |
bodsmate
Posts: | 21 |
I get 18.7VAC on a system which has been powered down for sometime.
I don't have a multimeter which can messure RMS (most don't) hence wanting someone with a standard multimeter to messure what they get.
I am leaving disconnected until I confirm if 18.7VAC on a normal multimeter is too much!
Posted: Wednesday Mar 21st, 2012 01:43 pm |
Are you measuring the voltage unloaded or connected to Comfort
An unloaded transformer will normally have a higher voltage. Dont worry about connecteing 19VAC for a short period to Comfort. It can take it
I wouldnt worry too much about the RMS readings in AC, it should be close enough
