Hope someone can advise, I am retrofitting Comfort into my house and hoping to reuse as much of the old alarm system as possible.
Have reverse engineered what all the old inputs are with no problems (so far) the only thing that has me stumped is how I can reuse the existing wall mounted external bell / siren.
The old alarm is a 9100 which connect to a 9066 SAB BELL MODULE. (Manual and circuit diagram attached).
There were orginally 6 wires that fed the external bell.
- 2 were connected to Trig + (although circuit diagram shows this as +VE)
- Trig - (circuit diagram shows this as - Ringing)
- 0v
- Tamper Return
- Strobe c
Anyone offer any advice on how it needs to be wired up?
My Thoughts were that 1 Trig + needs to go to 12VF
Strobe C needs to go to STR-
(I will use 12v battery to check which Trig+ is which and check when strobe comes on)
Other Trig+ needs to go to SRN+
TRIG - Goes to SRN-
Ov and Tampter Return I will connect to a zone input
Does that sound about right?
Cheers
Stuart
Attachment: alarm 9100USER.PDF (Downloaded 4 times)
