Are you using a Light Sensor Module (LSM) which is connected to an Input? The LSM output will be Open when it is dark and Closed when it is Light
You need to program the Zone number as Switch Normally Closed, so that when it is dark the zone is off and when it is light the zone is ON
The Zone ON Response should be the one that switches on the X10 for the set time. An example of the Response is shown below
X10 A1 On
Do X10A1OFF After 30 Seconds Using Timer05
The LSM Manual is attached. It is now discontinued
Attachment: lsmman.pdf (Downloaded 6 times)
