Posted: Thursday Nov 11th, 2010 06:02 pm |
gmcorrea
Not my lucky day! I have two Comfort installations: one at home and one at the office, each with their independent UCM and connected wirelessly to the same network. In a bout of bad luck, my router packed while I was updating my home Comfort configuration file, meaning that the transfer PC -> Comfort was cut off half-way. Now my Comfort at home is dead!
When I turn it on, all my 4 keypads are powered but don't have communication with Comfort (they make a soft continuous beep-beep sound), my strobe keeps flashing, my ethernet UCM (firmware UCM 5.156) is not accessible (with RDY LED on & D102 LED blinking & D103 occasionally blinking), my main board (PC01-070A, with firmware ULT 5.164) has a steady green LED on but my second output board (PC01-050B) has alternating Red & Green LEDs on, if I press Reset nothing happens.
Using my UCM I copied the NVM of my working Comfort (office) to the NVM of the dead Comfort (home) with success, but when putting the home NVM back Comfort was still dead.
I then put the home NVM into the office Comfort board (with no problem, since it was a copy of the office NVM) and transfered the home settings from PC to office Comfort board, essentially loading the home NVM with the home settings via the office Comfort UCM/board (after transfer I verified that by entering the home code with no problem). But when putting the home NVM into the home Comfort board still the same problem remained, with all the symptoms described above.
It looks like Comfort is not starting, even after recovering the NVM from the interrupted transfer. A friend suggested me that there could be a problem with the boot loader?!
Any help please?! :-)
Posted: Friday Nov 12th, 2010 03:17 am |
Posts: | 5493 |
When you reset the Home Comfort, do both the leds come on, then go off and the Green led come back on again and remain on?
If it does that, it means that the Comfort is not dead.
The keypads are beeping because there is no communications
This could be a problem with Comfort, or it could be due to another device holding up the Rs485 Bus. Disconnect all the devices from KA/KB. Then connect a keypad and see if it can sign in. If so then there is nothing wrong with Comfort itself. Connect the keypads and other devices back one at a time, and see if any device is causing the bus to hang
Posted: Friday Nov 12th, 2010 09:11 am |
gmcorrea
"When you reset the Home Comfort, do both the leds come on, then go off and the Green led come back on again and remain on?" Yes, that is exactly what happens.
"This could be a problem with Comfort, or it could be due to another device holding up the Rs485 Bus." I have many devices plugged into Comfort: before unplugging everything I just would like to understand how the interrupted transfer PC -> Comfort could affect any of them?!
If the problem lies with Comfort, what else could I try?
Thanks for the help!
Posted: Friday Nov 12th, 2010 01:23 pm |
Posts: | 5493 |
Interrupting transfer to Comfort should not affect any devices as we do it quite often
The advise is based on what you describe as keypads continuoulsly which means there is no communications on the bus
Removing the devices and reconnecting will help to determine which device if any could be affecting the bus
Posted: Thursday Nov 18th, 2010 04:10 pm |
gmcorrea
Hi, there!
I've unplugged the KA/KB connector, and when I power up Comfort the Green & Red lights turn on, and then the Red light turns off while the Green light remains on, never flashing. Shouldn't it start flashing after 10 seconds to indicate a communication failure? What would this indicate, a failure in the board? How could this be caused by an interrupted download PC->Comfort? By the way, with Comfort on the strobe is flashing if that helps in any way?!
Thanks for your help!Last edited on Thursday Nov 18th, 2010 04:43 pm by gmcorrea
Posted: Saturday Nov 20th, 2010 01:54 am |
There appears to be a fault on the Comfort PCB
Please return it to your Comfort distributor, or to Cytech directly with full descriptions of the fault, your name address and contact number
The address is
Cytech Technology Pte Ltd
55 Ubi Avenue 1 #07-04
Singapore 408935
Phone +65 68469701
Posted: Saturday Nov 20th, 2010 03:06 am |
gmcorrea
Thank you for your answer, Ident, though I was hoping not to hear that exactly... Any idea how an interrupted download PC-> Comfort via ethernet UCM could have damaged it?! I don't suppose I have a warranty after 2 years? :-) Thanks again...
gmcorrea
Maybe I'll swap the PCBs between home and work (swapping NVMs too) and see what happens... :-) Last edited on Saturday Nov 20th, 2010 03:09 am by gmcorrea
Posted: Saturday Nov 20th, 2010 03:15 am |
Swapping the boards is a good idea
Do not worry, even if your product is out of warranty any repair charges are nominal if the product can be repaired. Otherwise we will offer an upgrade in lieu of repair at a very reasonable price
Posted: Sunday Nov 28th, 2010 05:06 pm |
gmcorrea
Ok, I have finally discovered what is causing the home Comfort bus to hang! Considering that the Main board has two halves (which I will refer to as NVM half and Telcom half), when I swapped the (working) office NVM half with the home one everything worked fine. I then swapped the office Telcom half with the home one, and the same original problem occurred: no Comfort boot, with Green LED steady on, even when nothing is connected to Comfort. Swapping the office Telcom half back would bring everything to normal again. So the problem lies with the home Telcom half (PC01-051B 2), and I again ask: how an interrupted transfer PC->Comfort could affect it?! Anything I can do to fix it? Or should I have it replaced? Thanks for your help! :-) Last edited on Sunday Nov 28th, 2010 05:18 pm by gmcorrea
Posted: Monday Nov 29th, 2010 12:40 am |
Posts: | 5493 |
We refer to it as the CPU board and the DSP board. There seems to be a fault with the DSP half which needs to be sent back for repair as there is no much that you can do to fix it.
I dont know if interrrupting the Vocab transfer would have caused this. It may have left the voice in an unknown state. We will have to test it to find out more
Posted: Monday Nov 29th, 2010 05:57 am |
gmcorrea
Thanks for your help! I will be dropping my faulty DSP board with the local distributor so he can send it to you for repair. I will be purchasing another DSP in the mean time, so I can have a spare in case that happens again!!
Is there a way I can follow the progress of my board's repair with you guys?!
Posted: Monday Nov 29th, 2010 10:24 am |
Posts: | 5493 |
You can send an email to support@cytech.biz to check about the progress of the board. Record the serial number of the DSP board. Each section of the PCB has a different serial number eg P1234567
Posted: Monday Nov 29th, 2010 10:56 am |
gmcorrea
Cool! But the only "serial number" I can see is B0901, printed in black next to the battery connection; there is a barcode sticker but no numbers next to it...?! Last edited on Monday Nov 29th, 2010 01:32 pm by gmcorrea
