When you say that the CWM's LEDs stop flashing, do you mean D9 and D10 which indicates the communication between the CWM and Comfort? Or do you refer to the Network LEDs which are at the side?
If it is the former, do you get communication failure on Comfort? Is the CWM powered up (veirfy the green RDY LED).
If it is the latter, could the network connection be loose? Or could the network be down? It could also be that the adpator is disconnected.
