error while upgrading ULT
 Posted: Sunday Apr 11th, 2010 03:40 pm
WMADKOUR
we have a situation here, we can't solve
our system is ULT 5.145, UCM05 5.164, we was upgrading firmware for ULT  5.183
our engineer did  follow the step ( as it wasn't the first time for him)
but as he reported :
-connect ucm/serial to ultra  board and Pc.
-switch comfort off ( no battery )
-connect programming cable to pp1 on mpu01
-connect the other ends to ucm ( pp1 , pp3 )
-switch comfort on
-comfigrator , transfer , firmware download
-navigate firmware ult 5.183 ( .cbf )
-message :
1-firmware for controller type 254 v5.183.cbf will be upgraded ( ok )
2-error download
when we tried again, the attached message appear "product number or type doesn't match"
 and error msg on the keypad "keypad appear message " ID#1 VER 1.08r "
so your support is appreciated here :) thanks
Attachment: ucm-screen.jpg (Downloaded 14 times)
 Posted: Monday Apr 12th, 2010 01:42 am
You need to use UCM 5.178 or above to upgrade firmware. Your version 5.164 is not able to recover from an error like this during the upgrade. See forum http://www.comfortforums.com/forum4/1783.html whuch states the minimum UCM firmware to be used
If you have another UCM, you can use one to upgrade the other to the latest firmwqare UCM 5.200 so both are up to date
Once you have upgraded the firmware you can use it to complete the upgrading of the Comfort firmware
 Posted: Monday Apr 12th, 2010 09:29 am
WMADKOUR
done as charm..
UCM upgraded , ULT upgraded
me Grateful :)
thanks
 Current time is 01:23 pm
