Posted: Sunday Nov 15th, 2009 05:21 pm |
I'm using the latest posted Comfort Ultra Beta firmware.
I've had a problem with my ZWave lights for a while, getting spurious lockups, as described in another thread.
Montoring the comfort bus I'm now noticing spurious counter values.
Only reason I have spotetd is because i'm using my Comfort Client with sounds on for the lights so I hear the lights switch state.
An example, all my zwaves are straight switches (no dimmer versions) as I use CFL's; so I expect to send "00" for off and "FF" for on.
Just got a counter report from Comfort that went like this when the light is already ON (ie CT32FF)
CT32FA <- What's this!!
CT32FF
Another example
CT3501 <- What's this!!
These arent valid on/off counter responses. CTxxFF and CTxx00 are the only valid responses I should be getting.
Any ideas. Are the counters right and it's the logic on the UCM/Zwave that's causing. Dont know how to get to the bottom of this.
Posted: Tuesday Nov 17th, 2009 12:06 am |
leonchue
Posts: | 71 |
Can you send me the Comfort Bus monitor log, via PM, for analysis?
Thank you.
Best regards,
Leon
