Search
Search:
go
Search by username
Menu
Members
Calendar
Help
Not logged in -
Login
Register
Support
Problems & Troubleshooting
> TWS02
TWS02
Moderated by:
New Topic
Reply
Printer Friendly
Rate This Topic
Excellent
Good
Fair
Poor
Horrible
Author
Post
Posted: Tuesday Aug 5th, 2008 07:03 am
PM
Quote
Reply
1
st
Post
mrtae
Wednesday Jul 12th, 2006
41
Dear Chiu,
Would you mind to advice base on the attached drawing provide, it's the correct wiring connectivity been place?
Appreciate your advice, thank you.
Regards,
Tae
(Downloaded 25 times)
Posted: Tuesday Aug 5th, 2008 07:37 am
PM
Quote
Reply
2
nd
Post
Saturday Apr 29th, 2006
Singapore
5493
The Output connections are wrong
The centre 12V must go to the centre of the Comfort OP terminal block (12V) NOT -12V
The OP connection goes to the OP terminal of the Output terminal Block NOT +12V
regards
Current time is 11:12 pm
Support
> TWS02
Forum Jump -->
These Forums
....Forum/Website
....NEWS & Announcements
Support
....How to Use Comfigurator
....Automation Programming
....Responses and Actions
....Wishlist
....Wordlist
....Training
....FAQs - Technical
....FAQs - Users
....Troubles
....Vocabulary Issues
....Arming and Disarming
....Outputs
....Keypad
....Comfort I Issues
....Door Stations
....Comfort as Fire Alarm
....Firmware History
....Comfort Firmware
....Keypad Firmware
....Slave Firmware
....Technical Material
Products
....CM9001
....Logic Controllers
....KP06/KP06A/KP04A Keypads
....KP06A/KP04A Firmware
....Temperature Sensor
....UCM
....UCM/USB
....Ethernet UCM/ETH03
....UCM/Wifi
....UCM Firmware
....UCM Problems
....UCM/Pi
....UCM/ETH01 & UCM/ETH02
....GSM Module
....UCM/GSM Firmware
....IRIO
....Expansion Modules
....Relay/Automation Modules
....Door Stations
....Door Station Problems
....KT03 Firmware History
....SCS Firmware History
....RIO Firmware
Software Applications
....iOS Apps
....Comfigurator
....Comfigurator 2.X
....Comfort Android App
....ComfortClient
....Plug-in Development
....ComfortClient Plug-ins
....WizComfort
....Misc Software Interfaces
....KNX (EIB)
....KNX Support
....UCM/KNX Firmware
....CBus
....UCM/CBUS Problems
....UCM/CBUS Firmware
....Universal UCM
....UCM/Modbus
....Zwave
....UCM/Zwave Firmware
....Smart-House/Dupline
....C-Bus to KNX Translator
....Velbus
....UCM/Velbus Firmware
....Heatmiser
....ULTI
....Wireless Security
....Remote Controls
....Lighting Interfaces
....Access Control
....Miscellaneous Interfaces
....Companion
....X10
Comfort Around The World
....Cytech Media Coverage
....Assistive Living
....Events / Diary
....Miscellaneous UK Issues
....Comfort Installers Forum
....Security and Monitoring
General HA Information
....Miscellaneous
....HA in the News
Restricted
....Special Problems
UltraBB 1.172
