Foward X10 Comamands To Web
 Moderated by: adlim
 Rating:  Rating
 Posted: Saturday Mar 16th, 2019 11:15 pm
jjsg
I use confort since 2003, being the automation made by X10. I currently have 2 AD10 modules broken, but I'm trying to replace them with Sonoff modules or (Shelly 1).
I also have a CM15Pro module that uses Active Home Vista 2.5.5 application on my PC.
My question is how to send X10 commands to command these modules.
In other words, I need an application that receives for example the order
-> (A8 On) coming from Comfort
and create a web command that sends to Sonoff module via IFTTT
-> https://maker.ifttt.com/trigger/A8_on/with/key/cliKg4KMsyhtYIZL0GzIhN
JG
 Posted: Sunday Mar 17th, 2019 03:04 am
Comfort cannot send commands via IFTT by itself
The new UCM/Pi is able to do that see http://www.comfortforums.com/forum136/
 Posted: Saturday Jan 30th, 2021 06:43 pm
jjsg
For those who have an old CM1 Pro module , and ActiveHomePro software.
https://www.electronicoscaldas.com/datasheet/CM15A.pdf
It is possible to create a macro that sends a command to windows, in this case open the internet explorer and send the desired http command.
http://192.168.1.237/relay/0?turn=on ( shelly device)
It is evident that there will be a small delay, but for example if it is an action to closing all the blinds , in the house when we turn on the alarm, it is not very important.
And this delay in case off one shelly device is small, because is a local internet order.
The delay will be greater in the case of a sonoff module, as the order is sent to the IFTTT cloud.
JG
Attachment: Active Home macro.png (Downloaded 12 times)
 Posted: Monday Feb 1st, 2021 02:01 pm
A thoughtVERY MESSYBUT We have kept all the upgrade comfort C1 unit boards from al the upgrades we have done over the years.
Any one wanting X10 could use and old C1 board to talk to X10 then interface C1 to a new C2
Maybe not !
 Current time is 01:14 pm
