Posted: Friday Apr 18th, 2014 12:38 pm |
It has been suggested that X10 is obsolete and should not be included in new Comfort hardware. There are hardly any suppliers of X10 products, the technology is too old and too unreliable.
However the firmware will continue to support X10 for existing users with Comfort
Any comments from the Comfort community? Who wants to continue using X10 on new Comfort systems?
Posted: Friday Apr 18th, 2014 02:01 pm |
wexfordman
Posts: | 546 |
I removed x10 from my system a couple let of years ago and went completely with velbus. Was delighted to get rid of x10,more because of the improved reliability and functionality of velbus.
Couple of months later I reused to ad10 modules in my shed cos I could wire to it.
So, why remove it, you can still get modules, and it is handy for those awkward places to reach. I know other wireless solutions are available but that means having to install a ucm dedicated for it.
Posted: Tuesday Apr 22nd, 2014 06:53 pm |
Posts: | 771 |
YES REMOVE IT FROM THE MAIN PCB
I am sure that there must be an X10 RS232 interface that people could purchase.
What did happen to X10 di they file for bankruptcy AND why are X10 product still being sold - does anybody still manufacture them?
Posted: Tuesday Apr 22nd, 2014 10:02 pm |
Posts: | 562 |
I assume if the X10 circuitry is removed there will be space for something else, right? What are you guys planning for the future?
Posted: Wednesday Apr 23rd, 2014 09:19 am |
perhaps a built-in ethernet interface?
Posted: Wednesday Apr 23rd, 2014 11:40 am |
I guess it is one thing removing the interface from the main pcb (strange it was ever there in the first place so assume pre UCM times) and another to remove support in firmware. I'm guessing the firmware needs chipset support that is x10 dedicated rather than using generic hardware on the pcb?
I'm also guessing a lot would still be using and wouldn't want to be frozen on the last firmware that supports x10. Can something like ucm/universal be setup to support if you did do this as a replacement?
I can liken it to the switch from xp to win 7/8 and people needing time to switch.
Personally I switched to Zwave a while back!
Posted: Wednesday Apr 23rd, 2014 11:47 am |
Posts: | 5499 |
The support in firmware would have to remain for those who are already using x10
If there is a serial interface to X10, then the universal could be used
X10 was part of the Comfort PCB since the beginning in 1996 even before it supported keypads.It was the 1st widely used home automation device
But I doubt many new x10 products are sold now
It is being sold by Marmitek http://www.marmitek.com/en/products/home-automation-security/x-10-home-automation.php
Interestingly the website says
X-10 Home Automation Make your home a house of the future - today!
Posted: Wednesday Apr 23rd, 2014 12:06 pm |
Posts: | 562 |
I like the Ethernet idea. More space for other UCM's in the enclosure then :-)
Posted: Sunday May 4th, 2014 05:44 pm |
Julian.Driver
Posts: | 72 |
I have CBus for 90% of the lighting and other stuff, however there is no CBus device which I can use to control lamps which are plugged in to a power socket, so I have to use X-10, distasteful as it is.
If Schneider were prepared to launch their wirless devices in the UK all that would change however.
Posted: Monday May 5th, 2014 06:19 am |
Zwave is a better alternative to X10
If you have a few devices that should not cause any problems
Posted: Monday May 5th, 2014 08:10 pm |
HomeIQ
Posts: | 10 |
Personally, X10 served me well for many years, however, I think having a standard Ethernet I/o is the way to go, leaving third-party interfacing to the buyers choice of add on interface.
Posted: Friday May 9th, 2014 01:11 pm |
Posts: | 771 |
X10 DEAD!
Several years ago there were rumours that X10 had gone bankrupt.
Several key web sites STILL sell X10
I can NEVER get an answer to the question IS X10 bankrupt and are the sites selling X10 just flogging old (very old now) stock.
Certainly the only press i can find is about dodgy deals with asia - there appears to not have been any promotional activity or new products.
My conclusion some years ago was that X10 was bankrupt - however I struggle to see how several years later X10 products are STILL available - should we be told!
Any other info would be most welcome.
Posted: Friday May 9th, 2014 01:15 pm |
Posts: | 771 |
Comfort PCB
YES REMOVE X10 interface
DO NOT ADD the Ethernet module into the main pcb - that WOULD be madness..... If anything is going to be prone to change upgrades (hardware, firmware and software) its going to be an Ethernet module.
The on cost on the main board would i suggest put of people who want the flexibility of a modular solution - in some cases the phone line is more than adequate in other cases we can end up fitting 2 or even 3 main comfort units in large properties with out buildings the satellites are never going to require Ethernet.
Posted: Friday May 9th, 2014 01:22 pm |
Posts: | 771 |
X10 dead - its a mystery
However wikipedia has the following:
"" On August 2, 2013, X10 filed for Chapter 7 bankruptcy at the U.S. Bankruptcy Court for the Western District of Washington. As of the filing date, total company liabilities were listed as being in the realm of US$1.0M to $10.0M (one to ten million U.S. dollars).[2]"
So presumably Marmitek have been (are) selling 'old stock'...
Posted: Friday May 9th, 2014 01:30 pm |
Not necessarily selling old stock
X10 is bankrupt but the patents on the technology have expired so others can continue to manufacture it. Or Perhaps they bought the licence
so x10 is not completely dead
Posted: Friday May 9th, 2014 07:31 pm |
Posts: | 771 |
BUT
what you say may be true BUT there is NO new advertising Marmitek have nothing on their web site to promote X10 and news over the last 3 years again has nothing relating to X10.
IF someone had started to re-manufacture then they would have put some effort into marketing.
Posted: Thursday Mar 1st, 2018 07:19 pm |
17th Post |
phil1155
Posts: | 48 |
I am late in this session. But X10 is not dead, still being sold .(http://www.eurox10.com/Product/Micromodules/Actuators/AW12.htm)
I am considering the capabilities of comfort in receiving and sending X10 commands to build a communication Stream between comfort and a open source home automation software ( Jeedom) that have plugin to connect to x10 components.My goal would be to have comfort to be more imbricated to this HA Platform ( email, scenarios, cameras surveillance/recording..)
Has anyone made such a project work ( X10 or ?)thanks
Posted: Friday Mar 2nd, 2018 12:51 pm |
18th Post |
Posts: | 5499 |
But why use X10? why not ethernet, or RS232 or some other interface?
X10 is not reliable
Posted: Saturday Mar 3rd, 2018 11:14 am |
19th Post |
phil1155
Posts: | 48 |
Chiu, Id love too. but I have not the talent to make the small plug in to send command or get status through ethernet from php or json. If I have source model , I can copy it. Do you have?
Posted: Saturday Mar 3rd, 2018 12:20 pm |
20th Post |
Posts: | 5499 |
We are not familiar with these protocols but I am sure others will know
Current time is 04:23 am | Page: 1 2 |
