LW10U Question
 Moderated by: adlim
 Posted: Friday Feb 27th, 2009 12:16 pm
If I understand correctly this UK 2 wire  (no neutral) doesn't report statuses back to Comfort so if the switch is turned on/off locally then comfort won't know about it.  Anyone confirm this?
So then if it won't tell me then I want to try to poll but can't see an easy way for Comfort to do this via Actions.
Is there a way to to do this ( I have the 2 way TW7223E by the way)?
 Posted: Friday Feb 27th, 2009 12:29 pm
Comfort does not support the polling function on X10
At the time there were no modules that respond to polling commands, are you sure this LW10U does?
I thimjk the best way is not to use the local button, use another wall switch connected   to Comfort input to trigger an X10 command Thus it k=can keep track of the status
 Posted: Friday Feb 27th, 2009 12:34 pm
Ok, i didnt realise the X10 would need to explicitly support polling as well.  I guess it doesn't then as I bow to your greater knowlegde here.:)
J
 Current time is 11:17 am
