Posted: Tuesday Mar 19th, 2013 06:43 pm |
Posts: | 560 |
Hi Guys,
I've fixed a few bugs in the previous release version of the Comfort II Simulator. This one has a few added features and bug fixes.
I've also included an updated 'Sample 1.xml' floorplan that you can load on ComfortClient. This one has descriptions to all the objects so you can easily see which Inputs/Outputs will activate certain objects.
Just copy the 'Sample 1.xml' floorplan over the existing one, start the Simulator in any directory and point ComfortClient to the IP where the Simulator is running.
I've uploaded the Simulator to Google Drive, the link below is where you can find the Beta version.
https://docs.google.com/folder/d/0B8ULGMOeTrZwb2J1ZDZyTW1xaUU/edit?usp=sharing
If you find anything that is not working as expected then please let me know and I will fix it. For new features, reply to this post or just drop me a PM and I will add it to the list for the next release.
Just a side note: If the Simulator encounters an exception it will disconnect your connected Client. If you hear the 'Exclamation' sound, just check if the Simulator didn't kick you out. If so, try and recreate the problem and send me the details.
Enjoy,
IngoAttachment: Comfort II Simulator Revision History.pdf (Downloaded 11 times)
Posted: Tuesday Mar 19th, 2013 06:44 pm |
Posted: Tuesday Sep 9th, 2014 11:04 pm |
Posts: | 560 |
All,
I thought I might as well make available my latest Comfort II Simulator that I've been using to test all the ComfortClient development.
The updated version had an internal engine change and lots of stuff added to make it more streamline and to get into line with the newest Comfort II features.
As before, this is only a development tool and some stuff might not work as expected. Give it a try, play with it, it surely helps me when I don't have access to a real Comfort system and when in the mood to code something. The Help file however is still the old one but most of the stuff is fairly straight forward to understand.
Regards,
Posted: Tuesday Sep 30th, 2014 11:12 pm |
yasser zakaria
Posts: | 2 |
i cant open cclx file and get messege unsupported cclx file verson please correct and try again i use V3.6.4
Posted: Tuesday Sep 30th, 2014 11:21 pm |
Posts: | 560 |
There were some internal changes done by Cytech since 3.6.4, you need to upgrade to the latest version and save the CCLX file again. The Revision History states it's tested with 3.9.2.
I just tested an old 3.4.0 file and it works. Just try to load the file in Comfigurator and save it again, perhaps that might fix it. If not just send me the file and I will check to see what could be the cause.
Posted: Wednesday Oct 1st, 2014 10:37 am |
Posted: Wednesday Oct 1st, 2014 10:50 am |
Posts: | 560 |
Are you sure you are using the latest Simulator? It works here by me.
Posted: Wednesday Oct 1st, 2014 10:57 am |
Posted: Wednesday Oct 1st, 2014 06:58 pm |
msspower
Posts: | 5 |
The same happened with yaser is happened to tooIt doesn't accept the cclx file.I am using config 3.9.2Windows 7 service back 1
Posted: Wednesday Oct 1st, 2014 07:14 pm |
Posts: | 560 |
Are you running 1.2(1) Build 2618?
Posted: Wednesday Oct 1st, 2014 09:42 pm |
Posted: Wednesday Oct 1st, 2014 09:51 pm |
Posts: | 560 |
Like I said, that is the old version. Please download the latest from the same download location.
Posted: Wednesday Oct 1st, 2014 10:21 pm |
msspower
Posts: | 5 |
This version not working.
Windows announce this msg.
"ComfortII simulator has stopped working"
Problem event name:CLR20r3
Posted: Wednesday Oct 1st, 2014 10:23 pm |
Posts: | 560 |
Make sure you have .NET 4.5 installed. I'll add a check for the next version.
Posted: Friday Oct 3rd, 2014 11:58 am |
msspower
Posts: | 5 |
Many thanks.perfectly run after installing .Net4.5 Last edited on Friday Oct 3rd, 2014 12:32 pm by msspower
Posted: Friday Jan 19th, 2018 10:50 pm |
Posted: Saturday Jan 20th, 2018 05:57 am |
17th Post |
Posts: | 5498 |
Nice! Its long overdue
