Hi Guys,
It's almost a year since I posted an update to the Comfort II Simulator. A new version is available which includes some of the newer features of Comfort.
Some of the main features are:
1. 128 Zone support with Slave 6 and 7 support (I added this just for fun)
2. Support for the 'cm' command
3. Home Control feedback support
4. A few more DA commands
5. 16-bit Counter, Sensor and RA reply support.
and lots of small bug fixes.
The software is available from Julian's web site at http://www.futurehomesoftware.co.uk/index.html. Check under the Downloads section.
Please check the Help file if you are unsure, most things are fairly easy to use but if you are stuck then the forum is the place to post your questions and bugs found.
Remember: The Simulator is primarily written to assist with software development, the Arming/Disarming side of the Simulator is very basic and a few things might be different to the actual Comfort system.
Enjoy it, I use it on a daily basis when testing new ComfortClient code.
Regards,
IngoAttachment: Comfort II Simulator Revision History.pdf (Downloaded 6 times)
