Comfort II Simulator
 Posted: Sunday Apr 29th, 2012 03:23 pm
An updated Comfort II Simulator is available for download. If adds a few new features and some minor bug fixes. See below for information.
Support the Time Program (TP) feature. Time Programs are read from the CCLX file and can be changed using the TP command.
Support for Reminder (RM) commands. This feature is not implemented in Comfort yet but I decided I’ll give it a bash to see if I can do it.
Supports the Extended RA and Sensor feedback. To enable, set the UCM/General Firmware version to 6.020 or above. Default is 6.001.
Local User Database can now be edited in the Simulator. You can Enable/Disable and change user passwords for users 1 to 16. CCLX integration is also done, if you load a CCLX file then the Username field and capabilities updates to whatever you have configured.
Action Code 152 (DA98) is now supported for Comfort firmware 6.019 onwards.
Log Replay ‘Loop Continuous’ have now been activated.
The latest Simulator can be downloaded from http://www.futurehomesoftware.co.uk.
Enjoy,
PS. Attached is a modified sample floorplan for ComfortClient. This one uses Cbus actions to Switch the lights On|Off. To use it with the Simulator just load this new floorplan in ComfortClient and enable the UCM/Cbus in the Simulator. Just remember to rename the file extension to XML.
Attachment: Cbus Sample 1.txt (Downloaded 11 times)
 Current time is 07:53 pm
