The new Comfigurator 2.1.0 has been released.
V2.1.0
Bug fixes- Handle missing default template file saved in Registry
- Use correct defaults for Vocab and Voice settings when converting to different DspType
- Save currently selected combobox value if exiting while editing
- Allow right-click to terminate combobox editing
- Fix problems exporting/importing responses with references to IR codes
- Sort responses with numbers > 999 correctly
- Fix problem reading file with uncommented action codes in response
- Increase download timeout to cater for delays due to high Comfort activity
- Ensure number of timers is adjusted correctly when converting between filesystems
New features - Support for branch action codes, removing restrictions on use of IF/THEN/ELSE
- Support ANNOUNCE WORDS action in Response Wizard
