Comfort is now able to comply to the EN50131 European standards for Intruder Alarms and PD6662 (UK Implementation on the standards). CP9000-ULT/EN03 is the Comfort Control Panel part number using the new EN03 enclosure which has been designed for this purpose. Comfort firmware ULT 5.106 and above implement the requirements, and will be supplied for all orders for CP9000-ULT/EN03
Keypads require special firmware, designed as KP03E and KP04E, the E suffix meaning EN50131 compliant
The document "Comfort Compliance to EN50131 and PD6662" has been updated and can be downloaded from http://www.cytech-technology.com/temp/techinfo/EN50131_PD6662.pdf
Installers are advised to read and be familiar with the Comfort implemenetation of the standard. A Comfigurator default template pd6662.cct available from http://www.cytech-technology.com/temp/software/PD6662.cct gives the basic configuration for a compliant installation. This template will be part of the next release of Comfigurator (after 2.2.1)
