ADSL Protection/Passthrough Board
 Posted: Saturday Oct 24th, 2009 08:53 am
The APB01 ADSL Protection/Passthrough Board allows ADSL broadband signals to pass through Comfort without being affected, so that the ADSL modem can be plugged to Comfort TEL OUT, ie in any telephone socket in the premises
Normally the ADSL modem must be connected on TEL IN before the telephone line goes into Comfort, otherwise the ADSL signal will be affected by  the voice path in Comfort. Hence the ADSL modem could not be plugged into a telephone socket connected to TEL OUT without having the broadband speed affected.
The new APB01 plugs into the TEL IN and TEL OUT connectors and includes TEL IN and TEL out sockets to connect the incoming telephone line and the telephone wires to the home telephones. The ADSL modem is connected to the telephone in connection of the APB01 while the house telephones are connected to TEL OUT on the APB01
The APB01 also provides additional protection from surges on the telephone line from lighting and other disturbances. This will also help to protect the ADSL modewm and other telephone equipment connected to TEL Out
Attachment: CIMG0259 small.jpg (Downloaded 69 times)
 Posted: Saturday Oct 24th, 2009 08:55 am
The picture shows how the APB01 is plugged into the TEL IN and TEL Out connectors on Comfort
Note that the APB01 can be reversed in polarity on  the TEL IN and Out connections as the two connections are symmetrical
Attachment: CIMG0247 small.jpg (Downloaded 69 times)
 Posted: Sunday May 16th, 2010 03:23 am
The APB01 ADSL Pasthrough/Protection Board  fulfills two functions
  1. It allows ADSL signals to bypass Comfort, ie the broadband frequencies go to TEL OUT so that an ADSL m modem can be plugged into any telephone socket in the premises. Without this device, the ADSL modem must be installed before Comfort TEL IN
  2. It provides protection against lignting-induced voltage surges, thus helping to protect Comfort as well as your ADSL modem and telephones from damage. Hence this performs the same function as the TPB01 Telephone protection Board)
The board is in the form of a PCB with fingers that plug into TEL IN and TEL OUT terminal blocks. Another set of TEL IN and TEL OUT terminal blocks on the board allow the Telephone in and telephone out wires to be connected. The picture attached shows the APB01
Attachment: CIMG0259 small.jpg (Downloaded 71 times)
 Posted: Sunday May 16th, 2010 03:24 am
The picture shows an APB01 plugged into Comfort
Attachment: CIMG0247 small.jpg (Downloaded 71 times)
 Posted: Wednesday Jul 14th, 2010 01:22 pm
The APB01 Manual is now available, see attached
Attachment: apbman.pdf (Downloaded 12 times)
 Posted: Tuesday Aug 18th, 2015 11:22 pm
rollem
With the APB01 installed do I still need micro filters on each of the telephones and the ADSL modem connected to the TELOUT socket?
The manual shows them connected without but I suspect they are required. Maybe not on the ADSL modem but on the phones.
Thanks in advance,
Jon
 Posted: Wednesday Aug 19th, 2015 06:26 am
You should need the microfilter for the phone only, not the ADSL modem
 Current time is 12:41 pm
