New DS02 Door Station
 Posted: Sunday Nov 30th, 2008 03:28 am
Cytech is pleased to announce that we shall be introducing a new model of metal door station. DS02
The DS02 is in brushed stainless steel with IP45 or IK09 protectionm with options of colour camera, monochrome camera or no camera
The Front frame Module  is aluminium die cast, it is fixable to the built-in back box with 4 "snake eye" head screws (anti-vandal construction). Front frame Dimensions 140 x 140 mm anthracite.
Stock available in December
Attachment: DS02 small.jpg (Downloaded 144 times)
 Posted: Sunday Nov 30th, 2008 08:16 pm
ndh
Do you have pricing relative to the DS01 please?
Presumably it comes with the snake eyes tool?
Also will the tool be available separately?
 Posted: Saturday Dec 6th, 2008 01:50 am
The screwdrivers are standard tamper proof types and I am told that the products will be supplied with them
Another  photo of the audio only model
Attachment: matrix audio small.jpg (Downloaded 125 times)
 Posted: Saturday Mar 14th, 2009 06:07 am
See the bundles announced at http://www.comfortforums.com/forum25/1404.html for both DS01 and DS02 at very attractive prices
 Posted: Thursday Feb 25th, 2010 03:00 pm
Gentle Giant
Could someone help, I'll be installing the DS02/AVC bundle flush into a brick pillar alongside some front gates. The builder needs to know what space to leave for the panel but I'm not entirely clear. I've seen the dimensions of 140mmx140mm quoted above for the DS02 - is this correct, including the casing/back panel? and what's the depth?
Thanks in anticipation :)
 Posted: Friday Feb 26th, 2010 12:02 am
hendy
This issue has been asked before by another user, please see:
http://www.comfortforums.com/forum68/1626.html
 Posted: Friday Feb 26th, 2010 08:24 am
Gentle Giant
Ok thanks. I did search first but clearly not well enough!
One thing that's still not clear from the manual - how does the backbox get secured to the wall; do you have screws at the back (so the wall cavity should only be as deep as the MA71 (i.e. 68mm) and/or the side?
It looks like the cables are fed through the bottom of the backbox but if anyone could confirm?
 Posted: Friday Feb 26th, 2010 09:24 am
The attached diagram should give a better picture although it shows a two gang back box
This topic is now closed as it is meant for announcement of the product. Please post further questions on the Door Station forum here http://www.comfortforums.com/reply.php?topic_id=1241
Attachment: mi2284.pdf (Downloaded 10 times)
 Current time is 10:08 pm
