Posted: Monday Jan 7th, 2008 05:41 pm |
poweruser
Posts: | 4 |
Chiu,
Have you considered introducing a LEM / SEM that supports bus (rather than star) wired sensors, supported by either a range of compatible sensors, and / or a module to fit inside off-the-shelf sensors.
In my last install there were 48 inputs (pretty much one per sensor type per room), and despite running multiple sensors on a single multicore cable where possible, it was still a lot of wire, and made cable management into, and in, the panels time consuming if nothing else, not to mention the additional complexity of wiring the sensors themselves to pass through unused wires to the next sensor. In addition, it meeant two full-size, and one smaller panel, and all this for a domestic installation.
With a bus wired system, depending on the design, it ought to be possible to run numerous sensors on a single two-wire loop (assumes the signalling is modulated on the power-line), or at most four wires if power and signalling are kept separate.
A disadvantage I can see is that a cable or sensor fault could disrupt some or all of the other sensors on the same bus, so it would still be appropriate to run multiple busses, either in a cable with more cores, and / or in conjunction with star wiring, but to a much lesser extent than with current designs.
In theory, comfort could support all 64 inputs (or more), on a single LEM added the the base panel.
The I/O module added to a sensor need be no bigger than a postage stamp judging by DCC modules. (What brought this back to mind was the purchase of a DCC model railway set for my kids, which allows independant digital powerline control of multiple trains on the same track - the train modules are measured in millimeters, and cost a few dollars to manufacture:
Thoughts any one?
Regards,
Matt.
Posted: Tuesday Jan 8th, 2008 11:08 am |
Posts: | 1200 |
Do you have a specific bus wired sensor or system in mind?
Posted: Tuesday Jan 8th, 2008 09:22 pm |
poweruser
Posts: | 4 |
Hi Chiu,
None in particular, but there are plenty out there. Most though seem to be proprietary, and are part of systems that compete with Comfort ,which I obviously wouldn't want to encourage ;-)
That's partly why I was thinking more of a module that could be added to an existing sensor, so that Cytech doesn't have to go down the route of manufacturing PIRs, contact sensors etc - installers can continue to use thier preferred brand of sensor, retrofitted with the bus communication module.
Not sure if there's a "standard" for an alarm bus, but there are plenty of other bus communication standards that could be appropriated for alarm use.
Matt.
Posted: Wednesday Jan 9th, 2008 11:47 am |
Posts: | 1200 |
Matt
Thats an interesting idea, something to be looked at in future, but quite a major design in itself, considering the need for reliability, power consumption etc.
C-Bus and EIB run their power and signal on 1 wire but their power supplies seem to be quite hefty and not amenable to battery backup.
Posted: Wednesday Jan 9th, 2008 03:08 pm |
palmlodge
Posts: | 507 |
My CBUS network is fully UPS'd. Comfort takes action with certain lights in the event of a power loss when it detects a power outage.
Posted: Monday Jan 28th, 2008 07:09 pm |
Posted: Tuesday Jan 29th, 2008 12:15 am |
Posts: | 1200 |
EIB sensors are not suitable for alarm purposes. They are not battery backed up and would fail when there is a loss of AC power.
If you really want to use an EIB sensor there is an action Do Alarm which you can use in the Zone Response which would trigger any alarm
Posted: Saturday Feb 23rd, 2008 10:51 am |
garym999
I have suggested this before. See here & here. What we need is for a system that allows for alot of expansion but without the complexity of lots of individual cable runs.
I had an old alarm system that used chips known as "ID biscuits" that could be wired to standard sensors. Very simple but very powerful as each and every sensor could be uniquly identified.
So I would love to see something like this too.
Posted: Monday Mar 10th, 2008 02:16 pm |
garym999
Take a look here... Although the site is orientated to weather monitoring it shows some of what is possible and available on a one-wire interface. There is also a HA section.
Also this a good reference for the ID Biscuits used in the alarm industry.
Posted: Tuesday Mar 18th, 2008 12:17 pm |
ndh
Dupline from Carlo Cavazzi might be another candidate ?
and would go further than just PIRs?
Has been requested elsewhere on the forum
Nigel
Posted: Wednesday Jul 27th, 2011 11:36 am |
ekarak
Posts: | 51 |
Hello all!
happy to pick up an old thread, but this is a flaming issue!! When a prospective client comes to see Comfort, first question is: can I replace my old alarm panel with this?
My answer right now is : "Yes but with some additional cabling..." : wrong answer, in existing houses you dont want to rip out existing cabling and start cabling all over the place...
The reason is most alarm cablings are cost-centric: as little wire as possible, run the same loop all over the perimeter etc etc.
1-wire (http://en.wikipedia.org/wiki/1-Wire) would be an ideal candidate for bus sensors. Low powered sensors are its main focus. just a pair of wires (signal & ground) to talk to devices up to 1000m away. with power coming in from Comfort's battery it should be easy doing it
I'm not sure about standards compliance though, I don't know what timing limitations or encryption/tampering prevention functions should be implemented.
Posted: Thursday Jul 28th, 2011 11:46 am |
1-wire is possibly something to be investigated
However you do not have to take out the exiting alarm wires to replace an existing alarm with Comfort. The alarm wires can stil be used, only that the keypads need CAT5 cable and need 6 wires whereas alarm keypads nornaly use 4 wires as theyu dont carry voice
