Posted: Sunday Jan 13th, 2019 06:27 pm |
Posts: | 771 |
We have a new Comfort CPU 9000 - I note the following updates:
- The 8 outputs are removed from the main pcb and are on a daughter board. Would it not have made more sense to utilise an 'output' UCM in this way it may have been possible to remotely connect or mount the utput board !
- EOL jumpers are now revoved and appear to work well in software. YES WORKS WELL.
- Tamper is now a three pin fixed to pcb - this is helpful for joining commons BUT its a different type of connector that sticks out of the side of the pcb - will this not cause problems in packaging !
- X10 removed - yep about time its totally redundent you cannot buy the X10 DIN modules now even Insteon replacements are not available.
Is there anything else we should know about!
Posted: Wednesday Jan 16th, 2019 03:10 pm |
Posts: | 771 |
I note that there is a new power supply
It appears to be a 15V DC (as opposed to the old 15V AC).
Presumably this is all ok with Comfort and has been soak tested etc.
Posted: Thursday Jan 17th, 2019 03:25 am |
Posts: | 5498 |
Can you send a photo of the new board and power supply, to make sure that you have the correct set?
