The current Voicemail hardware allows for up to 10 minutes of voice recording across all mailboxes. If people have 8 mailboxes in use does this size become a limitation. Yes that system will automatically remove the oldest message but does it do this even if it hasn't been read yet?
Would it be possible for Comfort to make use of cheap USB sticks in future to augment storage for areas such as this (logs maybe too) if otherwise the on-board memory is restricted.
Just a thought but a small daughtercard that somehow plugs into Comfort into which you can plug a 64GB memory stick and some software tweaks to firmware and voila..?
Probably not possible though!
