Protocol Manual
 Posted: Saturday Mar 31st, 2012 10:24 am
Quickie,
The TP command; what is the purpose/usage of the "FF - Ignore Enable" setting?
TP - Time Program (UCM 5.65, O4.209)
PC: TPttee[DD] [HH][MM] [RRRR]
UCM: OK
Sets the Time Program parameters
tt is the TimeProgram Number
ee=0 for on/off value, 0 = off, 1 = on, FF for ignore enable setting
DD for Day of week combination Bit 0 = Monday, Bit 1 = Tuesday,... Bit 6 = Sunday, Bit 7 = Holiday
HH for Hours in BCD notation 00 to 59 e.g. 22 is 10 PM
MM for Minutes in BCD notation 00 to 59 e.g. 45 is 45 minutes
RR for Response number - can be 1 byte or 2 byte response. If 2 byte responses, least significant
byte followed by most significant byte. If response < 256, the most significant byte (0) can be omitted.
Ultra version 4.216 will accept TP with 2 byte responses
Each TP message can set one or more parameters of the Time Program
 Posted: Saturday Mar 31st, 2012 12:23 pm
My guess would be that you can change the time of the program without enabling it to run.
 Posted: Saturday Mar 31st, 2012 01:03 pm
Yes, Ignore Enable means that the enable bits are not changed by the comand
 Posted: Saturday Mar 31st, 2012 03:20 pm
Nope you've still lost me on this one as to why you'd want to do this.
Neither Wizcomfort or Comfigurator allow you to set it to IGNORE so how/what would change it to that state?
J
 Posted: Sunday Apr 1st, 2012 01:46 am
You may want to change the time or the Response of the time program through the TP command but may not want to change whether that time program is enabled.
Otherwise if you make a change  to a time program you are forced to enable to disable it
 Current time is 09:19 am
