Posted: Saturday Aug 13th, 2011 09:37 am |
The new 6.xxx series module firmwares are absolutely brilliant. Many thanks for bring this feature to us...happy days!
Having seen ULT and UCM/GSM v6.xxx's this weekend (both of which I've sucessfully applied) I'd like to understand the dev schedule/order for the remainder.
Would it be possible for you to list out the UCM's in the order you are proposing to release including of course any already done? Dates if you can but we won't hold you to these of course, its just to give us a rough idea of your timescale thinking!
I'm also hoping you will release v6.xxx versions of firmware even if the only need for that release is to add the upgrade logic. Why? Because then we know we can remove the cover from the panel for the last time, upgrade all modules via the programming cable to v6.xxx and then that's the last time we need to do an upgrade via cover off.
Hope that makes sense and look forward to seeing a tentative schedule.
Posted: Saturday Aug 13th, 2011 10:28 am |
The ULT, GSM, UCM, SEM rev 6 firmware are already released, other will follow soon, (within weeks)
The new Comfigurator 3.3.1 was needed for better implementation of the firmware upgrade, and also the Comfort v6 is necessary to support upgrade of other modules on the bus, which needed tobe released
Since the products use a common code base, it is easy to produce new versions of these with just the Bus Upgrade support added.
However there is still some testing required to ensure that there are no unexpected bugs which may result.
Posted: Saturday Aug 13th, 2011 11:01 am |
OK,
If you have a ucm/Zwave 6.xxx I'd like to test it if and when available if you PM me when it's ready.
J
