ndh
While the ADM01 (passive distribution board) may not be the most interesting part of Comfort it can be quite useful where a case is crowded etc.
However even better might be a version where some or all of the following are covered:
- UCM sized so can stack better
- Contains fuse (or 2?) - resettable?, glass socket?, blade (car) socket? - this can typically be used when using the battery to provide door strike current
- Single relay as used DM02 / RLY01 - where no doorstation but single gate strike or a TV lift or Velux etc.
- Large con block for taking 10 plus PIRs etc.
- General purpose junction box for joining wires and holding unused cores etc.
- Tie down positions aka holes for tie wraps?
I am sure there may be other ideas out there?
Nigel
