WizComfort Setup Files
 Posted: Tuesday Aug 8th, 2006 03:31 pm
In Setup > Options > Files tab
the Config file location should be the location of your ccl file which has been downloaded to your system. This allows WiZcomfort to extract all the information about inputs, outputs, ucms etc that is set up in Comfort
The IFR files location is the location of your IFR folder in Comfigurator. This is usually Program Files\Cytech\Comfigurator\IFR. just click on any .fir file
The IOMAP location is whefre the main configuration file for Comfigurator is found. It is Program Files\Cytech\Comfigurator\iomap.cym
Attachment: wizfiles.jpg (Downloaded 156 times)
 Posted: Wednesday Aug 16th, 2006 04:11 pm
adlim
To add on, whenever the ccl file has been modified and downloaded into Comfort, the ccl file must be reselected in the Setup > Options > Files tab of WizComfort, and WizComfort must be restarted. This would then update the configuration loaded on WizComfort.
 Posted: Thursday Mar 8th, 2007 06:17 am
Patrick
Does WizComfort has a log file to log all the Comfort activities if the WizComfort is online 24hours?
 Posted: Thursday Mar 8th, 2007 11:26 am
No log file, but a simple way would be to leave the monitor on and just save the contents later
 Posted: Monday Mar 12th, 2007 11:01 pm
Patrick
May I know any other software that can log all the Comfort activities to a log file beside WizComfort?
 Posted: Friday Mar 16th, 2007 02:55 am
There is a thrid party Comfort Plug in for the Homeseer software, see http://www.comfortforums.com/forum28/
You will need the Homeseer software
If you have any questions, you will have to ask the developers of the software
regards
 Posted: Monday Apr 23rd, 2007 09:14 am
BMagalhaes
If this software is to be used as a User Interface is there any way to use it without having to install Comfigurator?
Is it possible to just have the folder for the IFR and CCL file?
It doesn't seem practical to ask the end user to install bought Softwares just to have Internet Access via Wizcomfort!
 Posted: Monday Apr 23rd, 2007 02:03 pm
Assuming you are talkingabout WizComfort, there is no need to install Comfigurator
You just need the ccl and ifr files
 Posted: Monday Apr 23rd, 2007 03:16 pm
BMagalhaes
Yes, I'm referring to Wizcomfort.
My concern is that It isn't very user friendly the installation process.
Would it be possible to have a single installation setup file that would create the necessary folders and then the installer would copy or ask the user to copy the CCL and IFR files to their folders.
I think that this way it would be a more professional installation.
 Posted: Tuesday Apr 24th, 2007 01:54 am
The problem with that is that in most cases, the ccl and irf files  that need to be used by the user may not be know at the time you install the Wizcomfort software, so they would need to manually copy the required file anyway
 Posted: Tuesday Apr 24th, 2007 06:16 am
BMagalhaes
In fact I agree with you but my intention is to make the installation of Wizcomfort as simple as possible for the end user and I think that it could help if the Installation Setup File from Wizcomfort could creat the necessary folders when runned.
If so, the installer just had to ask the user to copy the files to
C:\programs files\cytech\comfigurator\ifr
and
C:\program files\cytech\comfigurator
 Posted: Wednesday Apr 25th, 2007 02:02 pm
Will take note of it when we next release the software
 Posted: Friday Oct 16th, 2009 10:37 am
13th Post
JNo
I know there is going to be a new version of WizComfort, but where can I download version 1.4.6, its not available on http://www.cytech.biz/software.html ?
JNO
 Posted: Friday Oct 16th, 2009 01:03 pm
14th Post
You can download from http://www.cytech-technology.com/temp/software/Wizcomfort1_4_6.zip
But be warned that it may not work so well with the new Comfort II
 Current time is 01:49 pm
