Posted: Sunday Apr 21st, 2019 11:16 pm |
waynebr
Posts: | 89 |
I'm not sure what has happened but during my updates and reprogramming I have lost my Vocabulary, I have tried updating using Myma39 in an attempt to rectify this but I get the beeps on the keypad and then I get a vocab errors message. Can you advise on how I fix this. Attachment: vocab Errors.jpg (Downloaded 45 times) Last edited on Sunday Apr 21st, 2019 11:18 pm by waynebr
Posted: Sunday Apr 21st, 2019 11:18 pm |
Posted: Monday Apr 22nd, 2019 05:11 am |
Posts: | 5498 |
I assume you have not gone through the Vocab Upgrade YetThe error means that the vocab is incorrect. If you do the vocab Transfer then you will not get the message
Posted: Monday Apr 22nd, 2019 08:48 am |
waynebr
Posts: | 89 |
Hi the only option I can find is transfer>Vocab Upgrade, This is where I get the error. IS there another way I should be doing this?
Posted: Monday Apr 22nd, 2019 08:54 am |
Posts: | 5498 |
That is correct.Can you ignore the error and continue with the vocabulary upgrade
Posted: Monday Apr 22nd, 2019 09:13 am |
waynebr
Posts: | 89 |
No it looks like it stops at this point, The keypad then starts displaying not polled.
Posted: Monday Apr 22nd, 2019 09:15 am |
Posts: | 5498 |
If is normal for the keypad to show not polledThe vocabulary upgrade takes 20 Minutes You should let it continue in null there is an error messageBut you should upgrade the ucm and comfort firnware beforehand
Posted: Monday Apr 22nd, 2019 10:01 am |
waynebr
Posts: | 89 |
Hi it dosn't look like it will continue, the error message stays up and if I click OK it closes the progress bar. If I ignore it the progress bar stays on 0% and the keypad says no text data - download aborted.
Posted: Tuesday Apr 23rd, 2019 06:38 am |
Posts: | 5498 |
Can you open the UCM IO Monitor before doing the vocab upgrade, clear the screen, then after the Vocab upgrade attempt, press Copy to Clipboard and show the resultsAlso please check the serial num ber on the Comfort, C or P with 6 digits
Posted: Tuesday Apr 23rd, 2019 07:41 am |
waynebr
Posts: | 89 |
HI Below are the results from the IO Monitor.
Serial Numbers:Ultra 2 = P052504, Eth02 = P071567
Attachment: Document1.pdf (Downloaded 3 times) Last edited on Tuesday Apr 23rd, 2019 08:09 am by waynebr
Posted: Wednesday Apr 24th, 2019 05:12 am |
Posts: | 5498 |
I see that you are using ETH02ETH02 fails when trying to upgrade the vocabulary. It was obsoleted about 7 years ago
I suggest changing to ETH03
Posted: Wednesday Apr 24th, 2019 07:08 am |
waynebr
Posts: | 89 |
So I'm clear are you saying the eth02 is failing so an eth03 will fix the issue?
waynebr
Posts: | 89 |
If this is the case I might have to wait till the pi module is released Last edited on Wednesday Apr 24th, 2019 07:16 am by waynebr
Posted: Wednesday Apr 24th, 2019 07:56 am |
Posts: | 5498 |
No ETH002 is not faulty, but it does not handle the Vocab Upgrade, whereas ETH03 canYou can buy an ETH03 submodule to plug in to the UCM to replace ETH02.
Posted: Saturday May 11th, 2019 04:13 pm |
waynebr
Posts: | 89 |
Hi I have now replaced the Eth02 with a Eth/PI, I'm still getting vocab errors when trying to upload it. I have attached the log.
***Apologies - Ignore this Matt has just told me that the UCM /PI does not support binary text yet. I will review again when it does ***Attachment: comfort_vocab_error.txt (Downloaded 0 times) Last edited on Saturday May 11th, 2019 05:16 pm by waynebr
Posted: Sunday May 12th, 2019 01:57 am |
Posts: | 5498 |
I suggest you send the DSP board to Laser. They have a Voice programmer module that can reprogram the Vocab. If that does not work then that DSP board may be faulty and needs to be replaced
Posted: Sunday May 12th, 2019 11:50 am |
17th Post |
waynebr
Posts: | 89 |
Thanks I will wait until the new firmware is released for the UCM PI and try that. Otherwise I will need to take the board out and send it off.
