Posted: Tuesday Feb 13th, 2018 04:38 pm |
Posts: | 5499 |
Comfigurator 3.12.1
Bugs Fixed from 3.11.4 - Home Control Menu in some view modes did not work
- Graph References caused exception if a printer is not set up
- Fixed bugs in View modes
- IRIO when IR Signal Output was mapped to Counter and changed to Flag, an exception occured
- In Modbus, if Display mode is Decimal when the file is opened, when you go to the Modbus to comfort, the display is hexadecimal. To show as decimal, you must change the mode to hexadecimal and back to Decimal, then the display is in Decimal.
New Features- Re-origanised the display of screens in Comfigurator categories to make it easier to access http://www.comfortforums.com/forum20/4763.html
- View Mode: Automation has been added to other view modes (User, Simplified Engineer, Advanced Engineer, EMS). The view mode is now saved in the cclx file. Each default template has a default view mode. see http://www.comfortforums.com/forum20/4763.html
- Added Multi-Convert actions (Action code 159) - Convert deg F to C, Deg C to F, Convert (0-99) to (0-255), Convert (0-255) to (0-99). From Firmware 7.128. http://www.comfortforums.com/forum20/4765.html
- Added Action Code Toggle Counter (action) 158. This treats the counter as a binary object. If the counter value is 0, it becomes 255. If the counter value is >0, it becomes 0. From firmware 7.100
- KP04A/KP06A Properties - Tamper is disabled by default. Most users disable Tamper so default disable is more convenient
- Status of Flags, Counters, Outputs can be set, cleared or value changed (for counters) http://www.comfortforums.com/forum20/4764.html
Comfigurator 3.12.2
Known Issues- UCM/EHG - ehome to Comfort cannot select Comfort registers - pulldown menu is blank
- Vocabulary Upgrade error - For some systems Vocab u[pgrade stops at 23%, 50% and comfort is reset. Do not attempt Vocab upgrade at this time
- In View Modes; Automation and EMS, the Control Menu status checkbox is shown, but the actual status is not displayed
The changes in the new beta software are
UCM/Cbus2- For Learn mode and Monitor mode, the sent and receive messages to Cbus ae shown (instead of just received messages). The sent and received message are converted to ASCII for display
Time Programs- Time programs screen has number for Time programs. Time program number ie 1 to 32 is displayed so that when programming, users can relate to the number
Scan Modules- If you open a cclx file which is different Comfort eg Open Comfort 2 Optimum but connected to Comfort 2 Ultra, after Scan for modules, the wrong model was displayed. Now Comfigurator will show the actual scanned model regardless of the open cclx file
View Modes- Fixed bug - In View Modes; Automation and EMS, the zones status checkbox is missing
- Known Bug - in In View Modes; Automation and EMS, the Control Menu status checkbox is shown, but the actual status is not displayed
GSM Priority- Name of the Unused Bit 6 in Configuration flags change to to "GSM Priority Dialout (Requires firmware 7.136) and above. This causes dial out by UCM/GSM4 as priority even when the phone line is connected. By default, system will dial by fixed phone line, and when phone line is down, will dial out by GSM
Note that Windows XP is not supported after Comfigurator 3.12.1
Posted: Thursday Mar 1st, 2018 05:58 pm |
Posts: | 5499 |
Comfigurator 3.12.3
Bugs Fixed
- for UCM/EHG The drop down list to select Comfort registers is missing
- Control Menu did not show status in Simplified, automation, Simplified Modes
- HIO upgrade when atte,pting to upgrade message "Selected module is not in the configuration "
- In IRIO, Tx codes in IR codes Sets cannot select operation code. When file is saved and loaded then it is ok
- In some cases, Vocabulary Upgrade has error at 23% and 50% and was not able to continue from last address. It should be able to continue from last address now
New Features- UCM GSM4 > Properties Alphanumeric ID default is "Cytech"
- Supports new CM9001-EMS Environmental Monitoring System Product and KP04A
Posted: Saturday Mar 10th, 2018 08:37 am |
Posts: | 5499 |
Comfigurator 3.12.3 has been released.
Comfigurator should prompt to upgrade, otherwise upgrade from Help > Check for Upgrades
Posted: Sunday Jul 29th, 2018 08:46 am |
Posts: | 5499 |
Comfigurator 3.12.5
The changes in Comfigurator 3.12.5 are below
Note: This version was available in April but we have forgotten to announce it.
Bugs- Virtual Input – Virtual input action ddoes not affect Virtual input attribute of zone
- KP04A prevent changes can be seen in Alarm Mode, should be seen only in EMS
- Read User Codes only visible in Engineer Advanced mode, not in User or Simplified Engineer or EMS modes - Old bug
- Virtual Mode Drag/drop- if a Virtual Input zone is dragged to another zone, the new zone remains virtual but the reference remains at the previous zone number - Old bug
- In User Mode, Control menu with feedback and without actions cannot see feedback - Old bug
- User mode Control Menu press action key works 1 time only - Old bug
Changes and New features- KP04A "Prevent changes" field added to CM9001-EMS
Posted: Monday Jul 30th, 2018 12:27 pm |
Posts: | 5499 |
Comfigurator 3.12.7
Bugs- Read User Codes only visible in Engineer Advanced mode, not in User or Simplified Engineer or EMS modes - Old bug
- IRIO "Reset to default" button does a full read from IRIO
- HIO – when show status is checked, Read from HIO causes Unhandled exception
- Copy Counters Action does not cause addressed Counters to be shown as referenced (in blue) - Old bug
- In UCM/GSM4, when copying the text from Comfort for Control Menu, the check for 8 characters maximum for Control Action words is not done. Control Action words are limited to 16 for Alternative Text. Is the SMS any text with more than 8 characters in Control Action words is truncated - Old Bug
- After Scanning for Modules, the latest firmware for HIO, MSM01, TSM01 are shown as "Unknown"
- UCM/Modbus - In Modbus to Comfort Tab, check "Show Status " caused exception for some files
Bugs fixed - "If Virtual Input" condition caused exception
- TSM01 virtual Input when assigned cannot be unassigned, bug only in EMS, not in ULT
- KP04A EMS – Prevent changes should be seen in EMS Mode only, not Alarm Mode
Changes and New Features- Support for the new MSM01 MultiSensor Module is available
- Scan for Individual Modules has been removed. Only Scan for all modules is available
- Configuration > Voice Settings > Keypad and Phone Announcement Levels Minimum to Maximum Range on the slider have been changed to allow lower volumes for announcements
Posted: Wednesday Aug 1st, 2018 12:10 pm |
Posted: Saturday Sep 22nd, 2018 11:06 am |
Posts: | 5499 |
Comfigurator 3.12.8
Bugs- MSM01 - Default for "Water Leak Sensor Change Report" is wrong.
- MSM01 - Input 4 settings does not Write to EEPROM correctly. "Read from EEPROM" shows Input 4 is unchanged
- When IRIO Digital zone mapped to Virtual Input – the Zone Reference to IRIO is not seen
- In View User Mode, when Control Key has Sensor Feedback and no actions, the Sensor is not seen. It works in other view modes
Bugs Fixed- UCM/Modbus - In Modbus to Comfort Tab, check "Show Status " caused exception for some files
- RIO Digital Input mapped to Virtual Input, the Zone was not shown as Virtual
- Copy Counters Action did not cause addressed Counters to be shown as referenced (in blue)
- In UCM/GSM4, when copying the text from Comfort for Control Menu, the check for 8 characters maximum for Control Action words was not done. Control Action words are limited to 16 for Alternative Text.
- IRIO "Reset to default" button dID a full read from IRIO
- HIO – when show status is checked, Read from HIO causeD Unhandled exception
New Features & Changes- Sensor changes are recorded in Event log for CM9001-EMS only
- Browse for new template starts at Comfigurator's Config folder
- When Comfigurator writes to KP04A or KP06A and the partition is changed, Comfigurator sends reset o Comfort in order to load the new partition
- HIO added option for sensor NO/NC
- IRIO If Comfigurator is showing “Submodule- None†in either the 1st or 2nd submodule, show the detected sumodules in the correct location 1 and/or 2.
- IRIO Reset to Default should default to the 2 detected submodules if IRIO is connected, instead of to blank. (Previously Reset to Default gives a message that the IRIO installed is different from the currentconfiguration) so Reset to Default was no use when IRIO is connected
