Changing response numbers
 Posted: Thursday Nov 9th, 2017 10:22 pm
wexfordman
As my system has evovled, and I added/removed responses etc, my response order is a little disjointed. Is it possible to re-number response names, so I can get thigs a bit more ordered ?
For example, I have a respnse to turn a light on, resp 53, but the turn the light off resp is 102, so can I re-order these so the response numbers are 53/54 (noting that I would have to free up respnse 54 first)
Regards,Eamon
 Posted: Friday Nov 10th, 2017 07:14 am
If you want to trim the unused Responses, you can go to Edit ? Unfix All Responses
Then Delete all Unfixed and Unreferenced Responses. Be careful you may have some unreferenced responses which are needed.
This will leave only referenced responses in blue
You can Fix the Response number of each response indiviually
 Current time is 05:14 pm
