Comfigurator 3.12.1
 Posted: Saturday Sep 30th, 2017 02:33 pm
Bugs Fixed from 3.11.4
  1. Home Control Menu in some view modes did not work
  2. Graph References caused exception if a printer is not set up
  3. Fixed bugs in View modes
  4. IRIO when IR Signal Output was mapped to Counter and changed to Flag, an exception occured
  5.  In Modbus, if Display mode is Decimal when the file is opened, when you go to the Modbus to comfort, the display is hexadecimal. To show as decimal, you must change the mode to hexadecimal and back to Decimal, then the display is in Decimal.
New Features
  • Re-origanised the display of screens in Comfigurator categories to make it easier to access http://www.comfortforums.com/forum20/4763.html
  • View Mode: Automation has been added to other view modes (User, Simplified Engineer, Advanced Engineer, EMS). The view mode is now saved in the cclx file. Each default template has a default view mode. see http://www.comfortforums.com/forum20/4763.html
  • Added Multi-Convert actions (Action code 159) - Convert deg F to C, Deg C to F, Convert (0-99) to (0-255), Convert (0-255) to (0-99). From Firmware 7.128. http://www.comfortforums.com/forum20/4765.html
  • Added Action Code  Toggle Counter (action) 158. This treats the counter as a binary object. If the counter value is 0, it becomes 255. If the counter value is >0, it becomes 0. From firmware 7.100
  • KP04A/KP06A Properties - Tamper is disabled by default. Most users disable Tamper so default disable is more convenient
  • Status of Flags, Counters, Outputs can be set, cleared or value changed (for counters) http://www.comfortforums.com/forum20/4764.html
Please download from http://www.cytech.biz/comfigurator.html for testing
Please note that 3.12.1 is the last version that is supported on Windows XP
 Posted: Sunday Oct 8th, 2017 12:36 pm
This post describes the new Viewing Modes feature of Comfigurator 3.12.1
http://www.comfortforums.com/forum20/4755.html
 Posted: Saturday Oct 28th, 2017 10:06 am
Comfigurator 3.12.1 has been released
Please take note of the release notes at the top of the thread as  there are several important changes
 Current time is 07:18 am
