Comfort Server Manager
 Posted: Tuesday Aug 15th, 2017 02:12 am
Gary
I have a telemetry device connected to the same LAN as Comfort, which it seems uses an ethernet to serial port interface from the same manufacturer as used in Comfort.  When the telemetry device (TEK608 Broadband gateway) is connected, Comfort Server Manager becomes unusable due to a constantly flickering display that will not respond to keyboard input.
I suspect the issue is that Comfort Server Manager is identifying both devices in rapid succession.
Is there any solution to this other than separating them on different subnets?
 Posted: Tuesday Aug 15th, 2017 06:02 am
which UCM Eth do you have ETH01, 02 or 03? These arre from difrfrent manufacturers
If you disconnect the other device, does Comfort Server manager work correctly?
 Posted: Sunday Aug 20th, 2017 06:09 pm
Gary
It's an ETH03
Yes, all works as expected when the other network device is removed from the network.  For reference, the telemetry system is a TEK608 IP Modem manufactured by Dunraven Systems.
 Posted: Sunday Aug 20th, 2017 10:34 pm
Gary
CSM discovers the Eth03 using a UDP broadcast method. It would be interesting to see what a wireshark trace of your device looks like. Would you be able to capture a wireshark trace?
The only thing I can think of that your device might be doing is to continuously broadcast other data on the same port that CSM uses and this is probably what confuses it.
 Posted: Monday Aug 21st, 2017 06:45 am
Yes CS Manager only sends the request at the start and when you refresh, It doesnt like another CS Manafer session at the same time
You can disconnect the telemetry device to assign the IP address to UCM/ETH93 by CS Manager and close CS Manager It should not cause any problem if CS Mnager is not running so I dont think it will be a problem
 Posted: Tuesday Aug 29th, 2017 12:56 am
Gary
Thanks to all for your responses. I'm not always on site so disconnecting devices is a bit problematic. Ideally I want them to coexist so that I can access the system remotely if necessary. Unless there's another way, perhaps the best solution is to place the telemetry device on another subnet, although that's an option I'd prefer to avoid.
 Posted: Tuesday Aug 29th, 2017 07:01 am
If the problem is with Comfort Server manager, you do not need to access it after you set the IP address and Port. Once that is done, you dont need to run CS Manager anymore unless you wish to change the IP address and port again or upgrade the firmware
 Current time is 09:47 pm
